STL files for Mk2 Parts?
timsaucer
(@timsaucer)
I've ordered the 1.75 to Mk2 upgrade kit, but I've made some modifications to my current printer - notably adding cable chains and a few other things. I'd like to do the same before the upgrade kit arrives. Is there somewhere the new parts are posted? I don't see them in the same place as the original parts.
Posted : 09/06/2016 4:34 pm
christophe.p
(@christophe-p)
Member Moderator
Re: STL files for Mk2 Parts?
Hi Timothy,
the parts are here, you have to change the branch to go to MK2 branch 🙂
https://github.com/prusa3d/Orignal-Prusa-i3/tree/MK2/Printed-Parts
I'm like Jon Snow, I know nothing.
Posted : 09/06/2016 5:07 pm
kevin.b2
(@kevin-b2)
Cable chains sound like a sweet idea! If you don't mind sharing your STLs once you make something, i'd love to check them out.
Posted : 09/06/2016 5:20 pm
timsaucer
(@timsaucer)
Sweet! Thanks.
Hi Timothy,
Posted : 09/06/2016 5:54 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Kevin
I would suggest that sticking to the original cable management is the best idea, simple because there are too many things that can go wrong when deviating from a tried and tested method.
Peter
timsaucer
(@timsaucer)
That's a reasonable approach, but I've been very happy with my changes over the last 4 months. I'm very happy to see the Mk2 now mounts the end stops instead of using zip ties. That was my other main change.
Kevin
Peter
Posted : 09/06/2016 6:15 pm
