Startup Issues (Stuck on language screen)
[Closed] Startup Issues (Stuck on language screen)
vivosims
(@vivosims)
hey, i just completed my kit build and am attempting to start the printer, when i turn on the printer, the screen turns on and lists languages, i select English and then the screen flashes and then after a second or so goes back to the language screen. what do i do the remedy this?
Thanks Adam
Adam Champagne
(Rensselaer Polytechnic Institute School of Architecture Student)
Posted : 03/06/2016 2:15 am
Josef Průša
(@josef-prusa)
Member Admin
Re: Startup Issues (Stuck on language screen)
Hi Adam,
please check your LCD cables.
Seems like cable got punctured and when you press the button, you short the circuit.
Founder and owner / Majitel a zakladatel
Posted : 03/06/2016 2:26 am
vivosims
(@vivosims)
the green light blinks orange 2x
Adam Champagne
Posted : 03/06/2016 2:27 am
vivosims
(@vivosims)
the cables seem fine but i amattempting to investigate the lcd further
Adam Champagne
Posted : 03/06/2016 2:33 am
vivosims
(@vivosims)
we got it to work by fiddling with the lcd connector. thank you for your help,
Adam
Adam Champagne
Posted : 03/06/2016 3:05 am
Falcon
(@falcon)
I am having the same issue. I have checked my cables, there are no cuts or really tight bends, checked the connections, reseated the connections. I'm out of ideas.
Update.. maybe I should just read the manual... I was pressing the X button, which is reset, not the knob, which is used to select.
Posted : 17/10/2016 3:48 am
D1182
(@d1182)
Thanks Jexoteric, you solved my problem!
Posted : 09/12/2017 9:03 am
jonathan.r10
(@jonathan-r10)
Most useful RTFM post ever!
Posted : 13/01/2018 10:55 pm
david.m158
(@david-m158)
LOL, me too!
Posted : 12/01/2019 7:23 pm
toaf
 toaf
(@toaf)
the X button seems to get alot of people
Posted : 12/01/2019 8:45 pm
