Ringing in Y-axis
Can you help me diagnose this ringing in the Y-axis?
The bed alignment is perfect. I’m running Misumi rods and bearings. The y carriage is separated using the x frame so the y rods should be forced parallel.
I've checked to ensure the belts are tracking properly in the pulleys without obvious distress, and belts aren't rubbing on anything else.
The y and x belts are tight enough to strum, as instructed in the build manuals. This model is printed at the old default of ~50mm/s (I.e not at high speed linear advance).
The cube on the right was printed after the Y axis was loosened one notch, an the ringing is exacerbated.
Any other ideas as to how to diagnose?
Publié : 31/12/2017 6:19 am
