					                		prints fail on small part - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/</link>
                <lastBuildDate>Mon, 13 Apr 2026 14:44:26 +0000</lastBuildDate>
                        <title>Re: prints fail on small part</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30239</link>
                        <pubDate>Sat, 15 Apr 2017 18:38:49 +0000</pubDate>
                        <description><![CDATA[Yeahhhh that sound good !
Now i have to figure out &quot;modifier&quot; lol
Thanks !!]]></description>
                        <content:encoded><![CDATA[<t>Yeahhhh that sound good !<br/>
Now i have to figure out "modifier" lol<br/>
Thanks !!</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>ismanu</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30239</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30232</link>
                        <pubDate>Sat, 15 Apr 2017 17:49:43 +0000</pubDate>
                        <description><![CDATA[You can change print speed for a selected part of your model by using a modifier mesh.]]></description>
                        <content:encoded><![CDATA[<t>You can change print speed for a selected part of your model by using a modifier mesh.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>kevin.r5</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30232</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30214</link>
                        <pubDate>Sat, 15 Apr 2017 15:03:16 +0000</pubDate>
                        <description><![CDATA[hy richard,
i have bad experience with multi object. If  one object unstick... it is the end of your print ! Now i only print part by part, it s secure !!
So, i have tried a lot of settings...]]></description>
                        <content:encoded><![CDATA[hy richard,<br/>
i have bad experience with multi object. If  one object unstick... it is the end of your print ! Now i only print part by part, it s secure !!<br/>
So, i have tried a lot of settings.<br/>
KO : temp 255°<br/>
KO : temp 250°<br/>
KO : temp 250° + fan (thread ko, but the rest is good).<br/>
OK : temp 255° + fan + speed 60%<br/>
With this last settings, the thread is ok, and the rest too.<br/>
So for very small part you need to decrease the print speed, but i don't find  a "solution".<br/>
Like the "edit layer" in slic3r, a new tab will be welcoming ! :    &gt;  "Edit speed"<br/>
So you can change the print speed like you change the quality print ! <br/>
When you have a small part with hight detail, you can increase the quality and reduce speed for obtain a perfect print !<br/>
but the features does't exits.<br/>
I tried to change gcode "G1 Fx" but it's imposible... too many G1 in the file :( this must be done during gcode generation !!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30214</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30153</link>
                        <pubDate>Fri, 14 Apr 2017 15:35:49 +0000</pubDate>
                        <description><![CDATA[Also, you can print 2 or 3 copies to give each one time too cool.]]></description>
                        <content:encoded><![CDATA[<t>Also, you can print 2 or 3 copies to give each one time too cool.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>richard.l</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30153</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30141</link>
                        <pubDate>Fri, 14 Apr 2017 11:39:14 +0000</pubDate>
                        <description><![CDATA[thanks i will try !!]]></description>
                        <content:encoded><![CDATA[<t>thanks i will try !!</t>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30141</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30138</link>
                        <pubDate>Fri, 14 Apr 2017 11:28:20 +0000</pubDate>
                        <description><![CDATA[For the first, I would power on the fan after 10 layers or so by such tiny things.
Thomas]]></description>
                        <content:encoded><![CDATA[<t>For the first, I would power on the fan after 10 layers or so by such tiny things.<br/>
Thomas</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Knickohr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30138</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30136</link>
                        <pubDate>Fri, 14 Apr 2017 11:13:40 +0000</pubDate>
                        <description><![CDATA[:)  yeah i thinked the same way just now !
Too hot OR / AND too speed !
i use default prusa preset : 255° / speed 100%
i wil try to reduce]]></description>
                        <content:encoded><![CDATA[:)  yeah i thinked the same way just now !<br/>
Too hot OR / AND too speed !<br/>
i use default prusa preset : 255° / speed 100%<br/>
i wil try to reduce]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30136</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30132</link>
                        <pubDate>Fri, 14 Apr 2017 10:51:24 +0000</pubDate>
                        <description><![CDATA[Too hot.
Give the layers time to cool down.
Printing with fan on after a few layers and/or print slower.
By the way, the thread ist too fine, it will never be a thread.
                        <content:encoded><![CDATA[<t>Too hot.<br/>
Give the layers time to cool down.<br/>
Printing with fan on after a few layers and/or print slower.<br/>
By the way, the thread ist too fine, it will never be a thread.<br/>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30132</guid>
                        <title>prints fail on small part</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30130</link>
                        <pubDate>Fri, 14 Apr 2017 09:44:31 +0000</pubDate>
                        <description><![CDATA[Hello folks,
i don&#039;t arrive to print this stuff...
Maybe it is too small ?
I set :
infill retilinear 20%
brim : 5mm
filament ABS.
and i never arrive to print this stink.
I check all my b...]]></description>
                        <content:encoded><![CDATA[Hello folks,<br/>
i don't arrive to print this stuff...<br/>
Maybe it is too small ?<br/>
I set :<br/>
infill retilinear 20%<br/>
brim : 5mm<br/>
filament ABS.<br/>
and i never arrive to print this stink.<br/>
I check all my bolts and nuts, all is ok.<br/>
Vibrating ? (The printer is on "concrete")<br/>
if you have any ideas !<br/>
thanks, great day<br/>
<a href="https://i58.servimg.com/u/f58/17/39/08/20/slic3r13.jpg"><img src="https://i58.servimg.com/u/f58/17/39/08/20/slic3r13.jpg"></a><br/>
<a href="https://i58.servimg.com/u/f58/17/39/08/20/slic3r12.jpg"><img src="https://i58.servimg.com/u/f58/17/39/08/20/slic3r12.jpg"></a><br/>
<a href="https://i58.servimg.com/u/f58/17/39/08/20/img_2043.jpg"><img src="https://i58.servimg.com/u/f58/17/39/08/20/img_2043.jpg"></a><br/>
<a href="https://i58.servimg.com/u/f58/17/39/08/20/img_2044.jpg"><img src="https://i58.servimg.com/u/f58/17/39/08/20/img_2044.jpg"></a>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/prints-fail-on-small-part/#post-30130</guid>
