Printing spare parts - Can I get away with some parts in PLA?
david.b14
(@david-b14)
In reading the forums, any parts near the hot end must be ABS?
It is hard for me to use ABS because I don't have a fume vent setup so I will most likely use 3DHubs to get the hot end ABS parts. Should any other parts be printed in ABS only?
I heard that PLA can shift under constant load, so any parts under tension like the one involved with the belts should be ABS, correct?
Napsal : 12/11/2016 2:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Printing spare parts - Can I get away with some parts in PLA?
See this post: http://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/replacement-parts-t521.html#p3705
Peter
Napsal : 12/11/2016 2:59 pm
