Print Issue
I did my first print in MK2S printer.
I have 2 questions;
In my printing, my base seem does not look nice. See picture 1. Can teach me how to improve the base ?
Second, there is a join line in my printing. The join line is not straight. See picture 2. Can you teach me how to improve join line looks not so obvious or make it straight ?
Please see picture attached.
Thanks.
Re: Print Issue
Assuming you sliced with Slic3r, you can move the seam.
Printer Setting -> Layers and Perimeters -> Advanced -> Seam position
But that seem seems much larger than I have seen. Have you calibrated your extruder? Seems like you might be putting out too much filament.
As for the layer, was that the first or last layer? If first, see "Life Adjust Z - my way" thread under calibration.
If last layer, low down the print for the last layers.
