Pre-Heating time
mcnarik
(@mcnarik)
Pre-Heating time
Hi guys,
I would like to change pre-heating times before every print. I would prefer that bed starts first and nozzle later.
The reason is that nozzle is heated every time much faster than bed and meanwhile the filament is leaking. So I have to removed it manually every time before print.
So far I haven't found anything but is it possible to change settings in Slic3r, maybe?
I don't want to change gcode manually for every print...
Postato : 29/10/2017 6:10 pm
Re: Pre-Heating time
Have a search for PJR's
Start Gcode sequense. He heats the extruder to 170 C. And the bed to prefered temperature. Then does 9ppoint levelliing as the extruder works up to final temperature.
Regards Joan
Postato : 29/10/2017 6:54 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Here is is (MMU & KISS, so the variables - in angled brackets - will need to be changed):
; Prefix G-Code
T<EXT+0>
M201 X1500 Y1500 E900 ; set default acceleration
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
M140 S<BED> ; Heat the bed + 5 degrees for Mk2
M104 S170
M190 S<BED> ; Heat the bed + 5 degrees for Mk2 and wait
M109 S170
G28 W
M104 S<TEMP>
G80
M109 S<TEMP>
G92 E0.0
Peter
Postato : 29/10/2017 8:48 pm
