Offset in X axis
I have finished my upgrade but seem to have a strange problem. When I do an Auto Home the sensor looks like it lines up in the Y axis but is offset the left of the circle by about 1/2 inch. I don't see any way to fix this. It almost looks like the bed is turned around 180 degrees. There is another target at the other end that if the bed were rotated I think the sensor would drop right on it. Any thoughts?
Re: Offset in X axis
Robert
The first sensor position is not located at 0,0 so don't worry about it. If you have run the auto-home, then the probe found that sensor for the Z height and then moved X and Y to home
Peter
