Nothing works anymore
tung.d
(@tung-d)
Suddenly no motor is working anymore.
The selftest states error with x-endstop, but it doesn't even move, so of course it doesn't find endstop.
Turning it off and on, disconnecting from electricity for a minute. Reset. Settings move any axis: no motor makes a move. No filament can be loaded or unloaded. Printer does make a reset and freezes if settings / move axis / move extruder. There can not be disconnected any cable for all 4 motors I think... The only thing which works is moving around in the menu.
What we have directly done before: changing the filament.
Any hints?
Perhaps we should play in the new firmware?
Posted : 08/12/2017 12:22 pm
Re: Nothing works anymore
Have you checked your fuses?
there are two 12 volt feeds to the Rambo, one may have come undone / loose.
check the fuses with a test meter, as they can be fused but look Ok!
Best wishes, Joan
Posted : 08/12/2017 2:49 pm
Oh have you tried manually moving the extruder to the right on the X axis, and the Build platform to the front on the Y axis?
this may help show if the motors are only moving one way...
Posted : 08/12/2017 2:51 pm
