Move Z axis missing
I noticed sometimes after a print I am unable to move z axis higher as the Z axis is missing from the Move settings. X, Y and extruder move is there but not Z. If I shutdown printer it reappears. Is this normal?
Re: Move Z axis missing
At what Z height the printer finished printing?
I had the same problem. I've only looked for it when the print failed to get it back to home. So if I stopped the print then the move Z axis isn't there. I reset the machine and it is back so I can move it.
A better approach would be to restrict moving towards bed, I suppose the goal is to avoid hitting it? does this means the sense only detect specific points on bed but not sensitive to all? I'm seeing this too and will be nice to fix in later versions 🙂
I have this same question. It would be nice to move it up some times if I cancel the print.
