Model leaving outline print on bed after printing
les.b
(@les-b)
New to this and are wondering why the model outline appears on the bed after i have printed a model. It has just started doing it. Where the table is black.
The model outline shows up a light color. Please advise what i am doing wrong. The outline does not appear to have burnt in to the PEI sheet.
Please help
Thanks
Rehards
Les
Opublikowany : 28/08/2017 12:08 pm
AJS
 AJS
(@ajs)
Re: Model leaving outline print on bed after printing
This is normal, and will fade with time. I believe (not positive) it is just the PEI sheet that has been kinda stretched as you removed the print. With heat on the bead, it will go away.
Opublikowany : 28/08/2017 3:01 pm
steven.s14
(@steven-s14)
Most of the time for me with PLA it goes away after I do a rub down with IA. I usually do one rub down after I finish printing, and usually another before I start a new print if it's been a while between prints.
Opublikowany : 28/08/2017 5:09 pm
les.b
(@les-b)
Thanks Guys,
I didnt think it was much but all of this is new to me.
Regards
les
Opublikowany : 28/08/2017 7:16 pm
