Model leaving outline print on bed after printing
New to this and are wondering why the model outline appears on the bed after i have printed a model. It has just started doing it. Where the table is black.
The model outline shows up a light color. Please advise what i am doing wrong. The outline does not appear to have burnt in to the PEI sheet.
Please help
Thanks
Rehards
Les
Re: Model leaving outline print on bed after printing
This is normal, and will fade with time. I believe (not positive) it is just the PEI sheet that has been kinda stretched as you removed the print. With heat on the bead, it will go away.
Most of the time for me with PLA it goes away after I do a rub down with IA. I usually do one rub down after I finish printing, and usually another before I start a new print if it's been a while between prints.
Thanks Guys,
I didnt think it was much but all of this is new to me.
Regards
les
