MK2S LCD Support Bracket (With hex holes) STL file?
steven.s14
(@steven-s14)
Hey Guys,
I'm working on creating a holder for an automotive style rocker switch. And I'm looking at using the large hex hole in the LCD support to hold the holder. Unfortunately all of the STL files I've found have this hole being round. I'm sure functionally the part is exactly the same, but for my customizing it just doesn't work. I was wondering if this file does exsist somewhere? Yes, I could just measure the part I have (and I probably will), but I figured why reinvent the hex hole, when it's already been drawn?
Thanks for the help,
Steven
OH, I'm guessing both LCD_Support_A and LCD_Support_B will have the same hex, but if they are different, it is the one on the right I'm going to use.
Posted : 31/07/2017 1:01 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
steven.s14
(@steven-s14)
Re: MK2S LCD Support Bracket (With hex holes) STL file?
Yep, those are the ones I'm looking for. I'm not sure how I missed them on Github. I honestly did look there, but everything I seemed to fine, was just circular.
Thanks much. In the meantime, I had tried to take some quick measurements between running prints. On first glance, I was close, but not right on, so these will help out.
I'd call this answered if someone will let me know how to mark it as such.
Posted : 31/07/2017 3:18 am
3d-gussner
(@3d-gussner)
The default branch is MK2 when you go to https://github.com/prusa3d/Original-Prusa-i3 and not MK2s 🙂
Posted : 31/07/2017 2:26 pm
