MK2 Multi Material filament holder
benjamin.l
(@benjamin-l)
I was just trying to understand the MK2 Multi Material filament holder. Is there some dimensions you can give for size of filament it will hold. As an example, I use hatchbox a fair amount with dimensions
Spool Diameter: 7.88" - Spool Width: 2.69" - Spool Hub Hole Diameter: 2.20"
Thanks can't wait to get.
Posted : 06/12/2016 3:45 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MK2 Multi Material filament holder
Maximum spool width is about 95mm. All other dimensions are to a large extent irrelevant.
Peter
Posted : 06/12/2016 7:10 am
