        Lateral adhesion issues with Ninjaflex cheetah
I have been successfully printing the same object for weeks now with the same settings each time. Today, half way through my print, the layers stopped adhering laterally.
Printing with Ninjaflex Cheetah
I removed and cleaned the nozzle, it was partially clogged. Restarted the same print and after about 12 layers checked it. The left half of the print is laminated, the right half not at all.
The print did actually finish, I cut the top of the print open to see inside. But looking at the side, you can see the color change about half way up the print where it stopped adhering laterally.
Any ideas?
                            Posted : 12/10/2018 5:25 am
                    Re: Lateral adhesion issues with Ninjaflex cheetah
Maybe underextrusion due to some tension on the filament when the extruder moves. I now use to unwind the flex-material from the spool.
                            Posted : 12/10/2018 7:23 am
