Horrible Brim Quality with latest firmware
Hyperion Design
(@hyperion-design)
Hello everybody,
I always liked to print my models with brim. I never thought "Do I need it or not?" - I just did it, because I was on the safe side and it was so easy to remove.
But that totally changed with the latest firmware (the one that introduced Linear Advance).
The best case is, that the brim is very hard to remove, but I can still do it with a lot of time and use of my fingernails.
The worst case is (and that happens 95% of the time) that on half of the model, the brim is totally fused with the rest of the first layer. There isn't even a clean line between brim and the model. Then I need some tools (like a rasp or a very sharp knife), to remove the brim.
I use an Mk2s, and there is no difference, which presetting I use in Slic3r
Has anybody some similar problem, and a solution? Or something I could try? Thank you!
Posted : 28/02/2018 9:28 am
