Heatbed temperature not constant
danson tak chun.c
(@danson-tak-chun-c)
Hi I just found out the middle part of my heatbed temperature is 5-8 degree less than other area. Is this normal ? I have deep hole cased by the nozzle pushing down the heatbed one time and not sure if it breaks any track of the PCB heatbed.
Posted : 15/06/2017 12:35 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Heatbed temperature not constant
See this post: http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/bed-temp-100-but-ir-said-just-86--t4774.html#p34862 and many others. The forum search is very useful.
Peter
Posted : 15/06/2017 12:50 pm
phil.s2
(@phil-s2)
i don't think it will have broken the tracks - it may have delaminated, or pushed them apart, when hot
can you place a thin layer of aluminium on top of the pcb to spread the heat?
ok you will lose a little of your z height but it will allow better conduction across the whole area.
phil
helping others with 3d printer problems
building 3d printers
showing you can repair almost anything with a 3d printer and innovation - well, design!!
www.best3dprinter.stan-tech.com
Posted : 17/06/2017 9:19 pm
