FW 3.0.5 RC
3.0.5 FW Release candidate is out and ready for testing
Automatic calibration point locating
X/Y compensation if axes are not perpendicular
Printer stops if error occurs during calibration proces
Fixed time format in print statistics
Z-MIN set to 0.15mm
Improved serial communication
Check for a new FW update
PLA preheat set to 215/55’C
Automatic live adjust Z reset when printer recognises its been upgraded from MK1 to MK2 for the first time
Stack overflow fix
HOWTO video
MK2 hex files
NOTE
Make sure your start g-code has this sequence
G80 ; mesh bed leveling
If it normally runs the mesh bed levelling twice or more, it might cause error message to show up.
Re: FW 3.0.5 RC
Does this statement from the previous version still apply to this version?
DO NOT run calibration routine when any USB program connected ( Pronterface etc )
Re: FW 3.0.5 RC
Notes:
The new calibration process takes about 10 minutes.
There is a new settings menue item "Show end stops" where you can see the state of the end stops (0=anywhere, 1=at end position)
Should the printer be factory reset for calibration?
Does the value of the live adjust Z matter?
What's the meaning of "Check for a new FW update"
X/Y compensation if axes are not perpendicular: Would it be possible to show the compensation results/values?
Re: FW 3.0.5 RC
I am trying this firmware. Settings has "Calibrate Z" and "Calibrate X/Y". Both seem to do exactly the same thing.
I got this message, "X/Y skewed severely. Skew will be corrected automatically".
Re: FW 3.0.5 RC
Seems pretty fine! My X/Y calibration was perpendicular!
The calibrate Z only does the assumed Z-calibration for me, while the X/Y take a couple of minutes to scan the points.
I could also remove my added "x-stop-enhancer" now that the points are located better.
I found one problem, not sure if it's just me but, when I print (from SD this time) and stop the print, it just skips a few lines and then proceeds but with an offset, causing it to try to print outside of the bed.
Re: FW 3.0.5 RC
Factory reset won't hurt anything, but it should not cause any problems.
Live Z adjustment is disabled for the calibration.
It means that, with new release of drivers, there will be a special command in start gcode with the latest firmware number. When running the gcode on printer, it will compare the versions and notify the user about the new version.
Calibrate Z is the mesh calibration you see before every print. Calibrate X/Y runs longer and finds the point position for later calibrations.
The message measn exactly what is says. Angle between X and Y axes is not 90° and the printer will automatically compensate for it when you print, so 90° angle in gcode corner will print 90° on the printer 🙂
Can you be more specific? This seems like regular buffer behaviour from Marlin FW :-/ We plan to work on the buffer in the next releases.
Re: FW 3.0.5 RC
It's hard to describe, but I was doing a regular rectilinear infill. When I stopped it (using the lcd panel) I'd say it skipped 3 lines of code and just started the next line from a relative position (moved a bit x axis then keps going downleft) but since it was going to be a long line it exited the print bed and probably wanted to keep going but I aborted it.
Re: FW 3.0.5 RC
Hi, back from travel I wanted to give a go to this Firmware, so I started the printer, plugged the USB on the computer, launched Firmware updater and choose the 1_75mm_MK2-RAMBo13a-E3Dv6full.hex file.
Once the update started, the LCD screen showed the 4 lines of squares, but stalled on this stage and never went out of this state.
I even tried to redo the update but got the error:
avrdude.exe: ser_open(): can't open device "\\.\COM4": Acc�s refus�.
What may I do ? Should I restart the printer ? (I do not dare at this stage).
Help !
I'm like Jon Snow, I know nothing.
Re: FW 3.0.5 RC
I was unable to upload this FW via FirmwareUpdater too (4 lines on LCD and never ending update progress). I restarted the printer (with 2 lines on LCD - FW on rambo obviously corrupted) and tried it again with same result. So I tried older (last stable) 3.0.3 - uploaded without problem.
I still wanted 3.0.5. so I used Arduino to compile and upload.
Re: FW 3.0.5 RC
Just wanted to chime in with my experience.
So before using the firmware updater to update to 3.0.5, I factory reset my printer to be safe. The updating process might have taken a little longer than before or maybe it just seemed that way, but regardless, the firmware was applied successfully.
During the process of the X/Y calibration, my nozzle actually just barely made contact with the bed during the longer part of the calibration process when it hones in on each calibration point. So when I noticed this happening, I canceled the calibration, adjusted my z offset 0.2mm higher and restarted the calibration process and everything went smoothly from there. And the end result of the X/Y calibration process was quite good. Everything is aligned up pretty much perfectly.
James
Thoughts from a 3D printing newb.
Re: FW 3.0.5 RC
Ok, a quick update:
Rebooting my computer fix my write denied error, I was able to put back 3.0.3 firmware. I feel better now 🙂
I downloade again and tried to reapply 3..0.5 RC and got this error:
avrdude.exe: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude.exe: Device signature = 0x1e9801 avrdude.exe: reading input file "./fw.hex" avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: writing flash (186448 bytes): Writing | #######################################avrdude.exe: stk500_2_ReceiveMessage(): timeout ########### | 100% 41.00s avrdude.exe: 186448 bytes of flash written avrdude.exe: verifying flash memory against ./fw.hex: avrdude.exe: load data flash data from input file ./fw.hex: avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: input file ./fw.hex contains 186448 bytes avrdude.exe: reading on-chip flash data: Reading | ################################################## | 100% 20.12s avrdude.exe: verifying ... avrdude.exe: verification error, first mismatch at byte 0x0000 0x0c != 0xc1 avrdude.exe: verification error; content mismatch avrdude.exe done. Thank you.
Not sure how to fix that and why do I have this error in my situation.
At least rolling back to 3.0.3 worked like a breeze this time.
Re: FW 3.0.5 RC
So I just upgraded the firmware and ran the x/y calibaration, worked great. However the result came back "x/y skewed severely but will be corrected automatically." but everything looks straight and the prints have been coming out great.
How is that possible?
Re: FW 3.0.5 RC
The skewing is only relevant to the 9 probe positions. You may have to run the V2Calibration code again to reset the Z adjust.
For some reason, your bed is not square to the Z frame (twisted by a degree or two - not sure how that becomes "severe"...).
Peter
Re: FW 3.0.5 RC
one more thing, now the bedleving fails. "Sensors triggerd to high waint for reset" how do i fix that?
Re: FW 3.0.5 RC
Can I suggest a factory reset and retry the calibration?
Also ensure that the probe is positioned as per the manual. I think the probe should be just under 1mm higher than the tip of the nozzle.
Peter
Re: FW 3.0.5 RC
remind me again about the reset precedure, just hold the two buttons down until it beeps?
Re: FW 3.0.5 RC
Press and hold the knob; press and release the reset button; keep holding the knob until it bleeps.
Peter
Re: FW 3.0.5 RC
Was it during the printing?
Re: FW 3.0.5 RC
Thus happens directly after the mesh leveling procedure. The v2 calibration gcode worked though.
I tried a factory reset but my Z offset remains even after the reset. So the problem is still there.
Re: FW 3.0.5 RC
Now I have reset again, i checked the difference between nozzle and probe and the probe is 0,7mm higher then the nozzle.
After I reset I printed V2 calibration and started the batman gcode to further adjust the nozzle. After that I started the whistle gcode just to see it it started, thats the one that failed for me earlier, and it started so I stopped the print.
No I ran the x/y calibration and got a different message. Saying something like "All OK x/y is slight misaligned" I different message then before. It didn't mention anything about it being corrected automatically.
So I started the whistle again and after the bed leveling it just stops and I get the message again "Bed level failed, sensor triggered to high waiting for reset" and nothing happens.
What may be causing this, I'm starting to get a bit frustrerad.
Thanks for the help.
