FW 3.0.5 RC
Page 1 / 3
Josef Průša
(@josef-prusa)
Member Admin
FW 3.0.5 RC
3.0.5 FW Release candidate is out and ready for testing
  • Multiple measurements of calibration points and averaging the value
    Automatic calibration point locating
    X/Y compensation if axes are not perpendicular
    Printer stops if error occurs during calibration proces
    Fixed time format in print statistics
    Z-MIN set to 0.15mm
    Improved serial communication
    Check for a new FW update
    PLA preheat set to 215/55’C
    Automatic live adjust Z reset when printer recognises its been upgraded from MK1 to MK2 for the first time
    Stack overflow fix
  • HOWTO video
    MK2 hex files
    NOTE
    Make sure your start g-code has this sequence
    G80 ; mesh bed leveling
    If it normally runs the mesh bed levelling twice or more, it might cause error message to show up.
    Founder and owner / Majitel a zakladatel
    Posted : 13/07/2016 6:24 pm
    Pyr3x
    (@pyr3x)
    Re: FW 3.0.5 RC
    Does this statement from the previous version still apply to this version?
    DO NOT run calibration routine when any USB program connected ( Pronterface etc )
    Posted : 13/07/2016 7:51 pm
    TOTO
     TOTO
    (@toto-2)
    Re: FW 3.0.5 RC
    Notes:
    The new calibration process takes about 10 minutes.
    There is a new settings menue item "Show end stops" where you can see the state of the end stops (0=anywhere, 1=at end position)
    Should the printer be factory reset for calibration?
    Does the value of the live adjust Z matter?
    What's the meaning of "Check for a new FW update"
    X/Y compensation if axes are not perpendicular: Would it be possible to show the compensation results/values?
    Posted : 14/07/2016 6:38 am
    Shree
    (@shree)
    Re: FW 3.0.5 RC
    I am trying this firmware. Settings has "Calibrate Z" and "Calibrate X/Y". Both seem to do exactly the same thing.
    I got this message, "X/Y skewed severely. Skew will be corrected automatically".
    Posted : 14/07/2016 6:24 pm
    martorias
    (@martorias)
    Re: FW 3.0.5 RC
    Seems pretty fine! My X/Y calibration was perpendicular!
    The calibrate Z only does the assumed Z-calibration for me, while the X/Y take a couple of minutes to scan the points.
    I could also remove my added "x-stop-enhancer" now that the points are located better.
    I found one problem, not sure if it's just me but, when I print (from SD this time) and stop the print, it just skips a few lines and then proceeds but with an offset, causing it to try to print outside of the bed.
    Posted : 15/07/2016 11:21 am
    Josef Průša
    (@josef-prusa)
    Member Admin
    Re: FW 3.0.5 RC
    Factory reset won't hurt anything, but it should not cause any problems.
    Live Z adjustment is disabled for the calibration.
    It means that, with new release of drivers, there will be a special command in start gcode with the latest firmware number. When running the gcode on printer, it will compare the versions and notify the user about the new version.
    Calibrate Z is the mesh calibration you see before every print. Calibrate X/Y runs longer and finds the point position for later calibrations.
    The message measn exactly what is says. Angle between X and Y axes is not 90° and the printer will automatically compensate for it when you print, so 90° angle in gcode corner will print 90° on the printer 🙂
    Can you be more specific? This seems like regular buffer behaviour from Marlin FW :-/ We plan to work on the buffer in the next releases.
    Posted : 15/07/2016 1:40 pm
    martorias
    (@martorias)
    Re: FW 3.0.5 RC
    It's hard to describe, but I was doing a regular rectilinear infill. When I stopped it (using the lcd panel) I'd say it skipped 3 lines of code and just started the next line from a relative position (moved a bit x axis then keps going downleft) but since it was going to be a long line it exited the print bed and probably wanted to keep going but I aborted it.
    Posted : 15/07/2016 8:40 pm
    christophe.p
    (@christophe-p)
    Member Moderator
    Re: FW 3.0.5 RC
    Hi, back from travel I wanted to give a go to this Firmware, so I started the printer, plugged the USB on the computer, launched Firmware updater and choose the 1_75mm_MK2-RAMBo13a-E3Dv6full.hex file.
    Once the update started, the LCD screen showed the 4 lines of squares, but stalled on this stage and never went out of this state.
    I even tried to redo the update but got the error:
    avrdude.exe: ser_open(): can't open device "\\.\COM4": Acc�s refus�.
    What may I do ? Should I restart the printer ? (I do not dare at this stage).
    Help !
    I'm like Jon Snow, I know nothing.
    Posted : 15/07/2016 11:34 pm
    Cipis
    (@cipis)
    Re: FW 3.0.5 RC
    I was unable to upload this FW via FirmwareUpdater too (4 lines on LCD and never ending update progress). I restarted the printer (with 2 lines on LCD - FW on rambo obviously corrupted) and tried it again with same result. So I tried older (last stable) 3.0.3 - uploaded without problem.
    I still wanted 3.0.5. so I used Arduino to compile and upload.
    Posted : 16/07/2016 12:22 am
    Pyro
     Pyro
    (@pyro)
    Re: FW 3.0.5 RC
    Just wanted to chime in with my experience.
    So before using the firmware updater to update to 3.0.5, I factory reset my printer to be safe. The updating process might have taken a little longer than before or maybe it just seemed that way, but regardless, the firmware was applied successfully.
    During the process of the X/Y calibration, my nozzle actually just barely made contact with the bed during the longer part of the calibration process when it hones in on each calibration point. So when I noticed this happening, I canceled the calibration, adjusted my z offset 0.2mm higher and restarted the calibration process and everything went smoothly from there. And the end result of the X/Y calibration process was quite good. Everything is aligned up pretty much perfectly.
    James
    Thoughts from a 3D printing newb.
    Posted : 16/07/2016 8:14 am
    christophe.p
    (@christophe-p)
    Member Moderator
    Re: FW 3.0.5 RC
    Ok, a quick update:
    Rebooting my computer fix my write denied error, I was able to put back 3.0.3 firmware. I feel better now 🙂
    I downloade again and tried to reapply 3..0.5 RC and got this error:
    avrdude.exe: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude.exe: Device signature = 0x1e9801 avrdude.exe: reading input file "./fw.hex" avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: writing flash (186448 bytes): Writing | #######################################avrdude.exe: stk500_2_ReceiveMessage(): timeout ########### | 100% 41.00s avrdude.exe: 186448 bytes of flash written avrdude.exe: verifying flash memory against ./fw.hex: avrdude.exe: load data flash data from input file ./fw.hex: avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: input file ./fw.hex contains 186448 bytes avrdude.exe: reading on-chip flash data: Reading | ################################################## | 100% 20.12s avrdude.exe: verifying ... avrdude.exe: verification error, first mismatch at byte 0x0000 0x0c != 0xc1 avrdude.exe: verification error; content mismatch avrdude.exe done. Thank you.
    Not sure how to fix that and why do I have this error in my situation.
    At least rolling back to 3.0.3 worked like a breeze this time.
    Posted : 16/07/2016 12:27 pm
    Stefan
    (@stefan-8)
    Re: FW 3.0.5 RC
    So I just upgraded the firmware and ran the x/y calibaration, worked great. However the result came back "x/y skewed severely but will be corrected automatically." but everything looks straight and the prints have been coming out great.
    How is that possible?
    Posted : 16/07/2016 1:53 pm
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    Re: FW 3.0.5 RC
    The skewing is only relevant to the 9 probe positions. You may have to run the V2Calibration code again to reset the Z adjust.
    For some reason, your bed is not square to the Z frame (twisted by a degree or two - not sure how that becomes "severe"...).
    Peter
    Posted : 16/07/2016 2:30 pm
    Stefan
    (@stefan-8)
    Re: FW 3.0.5 RC
    one more thing, now the bedleving fails. "Sensors triggerd to high waint for reset" how do i fix that?
    Posted : 16/07/2016 3:01 pm
    PJR
     PJR
    (@pjr)
    Re: FW 3.0.5 RC
    Can I suggest a factory reset and retry the calibration?
    Also ensure that the probe is positioned as per the manual. I think the probe should be just under 1mm higher than the tip of the nozzle.
    Peter
    Posted : 16/07/2016 3:12 pm
    Stefan
    (@stefan-8)
    Re: FW 3.0.5 RC
    remind me again about the reset precedure, just hold the two buttons down until it beeps?
    Posted : 16/07/2016 3:22 pm
    PJR
     PJR
    (@pjr)
    Re: FW 3.0.5 RC
    Press and hold the knob; press and release the reset button; keep holding the knob until it bleeps.
    Peter
    Posted : 16/07/2016 3:57 pm
    Josef Průša
    (@josef-prusa)
    Member Admin
    Re: FW 3.0.5 RC
    Was it during the printing?
    Posted : 16/07/2016 4:02 pm
    Stefan
    (@stefan-8)
    Re: FW 3.0.5 RC
    Thus happens directly after the mesh leveling procedure. The v2 calibration gcode worked though.
    I tried a factory reset but my Z offset remains even after the reset. So the problem is still there.
    Posted : 16/07/2016 4:08 pm
    Stefan
    (@stefan-8)
    Re: FW 3.0.5 RC
    Now I have reset again, i checked the difference between nozzle and probe and the probe is 0,7mm higher then the nozzle.
    After I reset I printed V2 calibration and started the batman gcode to further adjust the nozzle. After that I started the whistle gcode just to see it it started, thats the one that failed for me earlier, and it started so I stopped the print.
    No I ran the x/y calibration and got a different message. Saying something like "All OK x/y is slight misaligned" I different message then before. It didn't mention anything about it being corrected automatically.
    So I started the whistle again and after the bed leveling it just stops and I get the message again "Bed level failed, sensor triggered to high waiting for reset" and nothing happens.
    What may be causing this, I'm starting to get a bit frustrerad.
    Thanks for the help.
    Posted : 16/07/2016 5:22 pm
    Page 1 / 3
