First Layer Uneven
I have a problem with uneven first layer over the build plate. Different locations have different layer heights. In this album you can see all the different locations: https://imgur.com/a/8PNqN . What can I do to fix this issue?
RE: First Layer Uneven
Hi, I have the same problem.
Despite bed leveling the first layer is very uneven. Do you habe a solution?
Assuming you both have MK2S printers because that is the forum we are in. Slacken the four corner screws holding the bed to the frame and slowly retighten each a little bit at a time so you don't constrain any of the corners before tightening the rest. Ensure you don't overtighten. Check the smooth rods are fully seated and restrained in the corner posts, and ensure the y-axis threaded rods are fully seated in the z-frame.
Bill
Tagaytay City, Philippines
