					                		Firmware Update Issue - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/</link>
                <lastBuildDate>Thu, 21 May 2026 16:54:55 +0000</lastBuildDate>
                        <title>Re: Firmware Update Issue</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-36622</link>
                        <pubDate>Thu, 06 Jul 2017 11:11:02 +0000</pubDate>
                        <description><![CDATA[Really sure the printer uses COM6 ?
Go to the Devicemanager and search for COM-ports. Is there Prusa.... listed ?
Thomas]]></description>
                        <content:encoded><![CDATA[<t>Really sure the printer uses COM6 ?<br/>
Go to the Devicemanager and search for COM-ports. Is there Prusa.... listed ?<br/>
Thomas</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Knickohr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-36622</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-36605</link>
                        <pubDate>Thu, 06 Jul 2017 04:44:39 +0000</pubDate>
                        <description><![CDATA[I&#039;m having the same issue myself related to the Firmware Updater v2.  I&#039;ve tried uninstalling different versions of the Prusa software, even attempted the original Firmware Updater back in 1...]]></description>
                        <content:encoded><![CDATA[<t>I'm having the same issue myself related to the Firmware Updater v2.  I've tried uninstalling different versions of the Prusa software, even attempted the original Firmware Updater back in 1.6.1.  I keep getting the following error:<br/>
avrdude.exe: ser_open(): can't open device "\\.\COM6": Access is denied. avrdude.exe: ser_drain(): read error: The handle is invalid. avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: stk500v2_getsync(): timeout communicating with programmer avrdude.exe done. Thank you.<br/>
I've verified the COM6 port is the active port in the device manager assigned to the printer.  Even Pronterface sees COM6 as the printer but can't connect due to access denied.<br/>
Connecting...<br/>
 Could not connect to COM6 at baudrate 115200:<br/>
Serial error: could not open port COM6:  Access is denied.<br/>
My printer still prints from the SD card but I can't update the firmware to 3.0.11.  Any ideas what to try next?</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>patrick.r3</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-36605</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-33157</link>
                        <pubDate>Tue, 23 May 2017 21:02:43 +0000</pubDate>
                        <description><![CDATA[Problem solved  :D
I powered down all devices, my windows-PC too, and start from scratch. Update works perfect.
Puhhh !!! Lucky  :mrgreen:
                        <content:encoded><![CDATA[Problem solved  :D <br/>
I powered down all devices, my windows-PC too, and start from scratch. Update works perfect.<br/>
Puhhh !!! Lucky  :mrgreen: <br/>
Thomas]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-33157</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-33144</link>
                        <pubDate>Tue, 23 May 2017 18:36:15 +0000</pubDate>
                        <description><![CDATA[:evil:  :twisted:
I will update to newest firmware 3.0.11, but the updater crashes while uploading the firmware  :o
Now it&#039;s not possible to update the firmware anymore  :cry:
avrdude....]]></description>
                        <content:encoded><![CDATA[:evil:  :twisted: <br/>
I will update to newest firmware 3.0.11, but the updater crashes while uploading the firmware  :o <br/>
Now it's not possible to update the firmware anymore  :cry: <br/>
<CODE>avrdude.exe: ser_open(): can't open device "\\.\COM15": Das System kann die angegebene Datei nicht finden. avrdude.exe: ser_drain(): read error: Das Handle ist ung�ltig. avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: Das Handle ist ung�ltig. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: stk500v2_getsync(): timeout communicating with programmer avrdude.exe done. Thank you.</CODE>
Help !!!<br/>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-33144</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25901</link>
                        <pubDate>Tue, 21 Feb 2017 17:25:27 +0000</pubDate>
                        <description><![CDATA[Let me guess,
You installed the RC, and now when you are attempting to update to the official firmware release your receiving those error messages?
This appears to be a bug in the release ...]]></description>
                        <content:encoded><![CDATA[<t>Let me guess,<br/>
You installed the RC, and now when you are attempting to update to the official firmware release your receiving those error messages?<br/>
This appears to be a bug in the release candidate.... <br/>
I found an old forum post where someone was experiencing the same issue with 3.0.9, and they got around it by using Firmware Updater V1......<br/>
However, I just contacted support and he had no idea which firmware package contains Firmware Updater V1.....<br/>
Does anyone know which firmware package it is in? Or even better a link to just the firmware updater v1? That would be greatly appreciated.<br/>
Cheers</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>tim.t</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25901</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25844</link>
                        <pubDate>Tue, 21 Feb 2017 00:08:36 +0000</pubDate>
                        <description><![CDATA[Maybe you are selecting the wrong COM number on the Firmware updater. You can check the right COM port on Windows:
Control Panel -&gt; System -&gt; Hardware Manager -&gt; Ports (COM/LPT)
                        <content:encoded><![CDATA[<t>Maybe you are selecting the wrong COM number on the Firmware updater. You can check the right COM port on Windows: <br/>
Control Panel -&gt; System -&gt; Hardware Manager -&gt; Ports (COM/LPT)<br/>
Choice the "Prusa" port number.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>manuel.i</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25844</guid>
                        <title>Firmware Update Issue</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25820</link>
                        <pubDate>Mon, 20 Feb 2017 17:13:16 +0000</pubDate>
                        <description><![CDATA[Just tried to update to the latest firmware 3.0.10 and I get this error on one computer 1:
avrdude.exe: ser_open(): can&#039;t open device &quot;\\.\COM4&quot;: Access is denied. avrdude.exe: ser_drain():...]]></description>
                        <content:encoded><![CDATA[<t>Just tried to update to the latest firmware 3.0.10 and I get this error on one computer 1:<br/>
avrdude.exe: ser_open(): can't open device "\\.\COM4": Access is denied. avrdude.exe: ser_drain(): read error: The handle is invalid. avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: stk500v2_getsync(): timeout communicating with programmer avrdude.exe done. Thank you.<br/>
To date I havent had one issue updating  from this computer. So I tried a second computer and that computer 2 cant even see COM4. Both printers show up as 'rambo' in device manager. Computer 1 cannot connect with Pronterface while Computer 2 can which is odd seeing as how the firmware updater cant see COM4. Any help is greatly appreciated!</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>ryan.o</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/firmware-update-issue/#post-25820</guid>
