Firmware 3.1.0 and repetier Server
we have two Prusa I3 MK2s. To Print we use two raspberry pi with repetier server installed but after the firmware upgrade it does not work anymore.
From the console I get the error Message:
Error:Line Number is not Last Line Number+1, Last Line: 0
Resend: 1
After this the server resends line 1
Resend: N1 M110
but the error message comes again in an infinite loop. My guess is, the Problem comes from the Firmware interpreting the command M110 (without any Argument) different then the last version. According to the Repetier server Forum ( https://forum.repetier.com/discussion/4561/line-number-is-not-last-line-number-1-last-line-0 ) the comment should tell the Printer to ignore line numbers.
But I think the printer interprets the code as "set current line number to 0". Downgrading to Version 3.0.9 "solves" the Problem but I would like to use the improved features of the 3.1.0 Firmware. Does anyone have any idea what could be done to solve this Problem without downgrading?
Best Regards
Re: Firmware 3.1.0 and repetier Server
I have the same issue with Repetier-Host.
Any solution for this? I guess a firmware patch is needed...
I've found a kind of soultion. I've used firmware from this link: https://github.com/thess/Prusa-Firmware It's 3.1.0 with patch for M110 command and it also has hyperfine bed leveling implemented. Now everything works fine for me with repetier.
