Filament Holder
brian.m18
(@brian-m18)
Filament Holder
Hi, there is nothing to hold the roll of filament except the left and right hooks...there is nothing to slide through the hook holes and through the filament roll. what do I use? Thank you.
Posted : 24/08/2017 9:43 pm
Re: Filament Holder
you could use apiece of pipe...
I do this, when the roll has a different size hole on one side!
I use pvc pipe that is a little larger than the pins on the holders. or cardboard roll from centre of toilet roll...
Posted : 25/08/2017 2:16 am
Bytor
(@bytor)
Re: Filament Holder
Currently I use a long bolt to slide through the provided filament holder. I also use a nut on the end, just in case the bold slides out of the holder, but I don't need to because of the length of bolt I used, plus it fits snuggly.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Posted : 25/08/2017 2:26 am
