[Fan failure] Filament molten inside of Extruder cold end.
marc.k
(@marc-k)
Hello,
I have some problems with my printer. At first it worked just fine. But in my last print the Cold End fan just stopped soinning and I did not notice it. I am pretty sure that filament got meltet inside the plastic tube. At least I cant stick filament in anymore. I disassembled the extruder and tried to follow the manual for tube exchange: http://manual.prusa3d.com/Guide/How+to+replace+PTFE+tube/82
However I rounded my nozzle with my 6mm wrench instead of unscrewing it. Now I dont see a way to get it off anymore. The extruder also seems to be no longer sold...
http://shop.prusa3d.com/en/3d-printer-parts/25-prusa-nozzle-mk2-full-metal-reprap-hotend.html
Can you guys (and girls) tell me how to salvage this situation?
Thanks
Posted : 09/09/2017 4:59 pm
AJS
 AJS
(@ajs)
Re: [Fan failure] Filament molten inside of Extruder cold end.
1) That is the wrong extruder. You want this one:
https://e3d-online.com/v6
but you probably only need this kit:
https://e3d-online.com/v6-block-sock-kit
If your heater is salvaged from the original.
2) Removing the nozzle should be done at very high temperatures.
Posted : 09/09/2017 5:41 pm
marc.k
(@marc-k)
Thank you. Yes I did know that you are supposed to be doing this at high temperatures. I let it preheat for PLA for a good 20min. (printed only PLA) Still happened... I will try and get it off again.
In case I have to buy the full kit: Is it 12V or 24V?
Also is it 100% compatible with the rest of the carriage?
And here some info to the failure: I am 99% certain that the fan was lose on the Rambo side. It was not really fixed in the plastic plug for the socket in the rambo. Pretty sure its a problem with these fans since I have read about other peoples failing fans.
Posted : 09/09/2017 6:33 pm
