Drivers 1.7.5 RC2 with Slic3r Prusa Edition (Updated 18 Nov)
Page 3 / 5
MrMik
(@mrmik)
Re: Drivers 1.7.5 RC2 with Slic3r Prusa Edition (Updated 18 Nov)
> But now even the old version of Slic3r is not working any longer in Ubuntu.... 🙁
You somehow got the new Slic3r installed over the old one, but likely only partially. I suppose you did not configure the perlbrew correctly.
The simplest you can do right now is to use our linux binary package. I have verified it runs on Ubuntu 16.04.1
https://github.com/prusa3d/Slic3r/releases/tag/version_1.31.6
Vojtech
Thanks, Vojtech!
I tried to install those packages before I tired the 'Git' approach above, but I could not get it to work.
For starters, I don't know if I need to use the " Slic3r-1.31.6-prusa3d-linux64-full-201611202210.tar.bz2 ", or the " Source code (tar.gz) " file.
I tried a few different approaches from this page: http://askubuntu.com/questions/25961/how-do-i-install-a-tar-gz-or-tar-bz2-file , using both the Slic3r-1.31.6-prusa3d-linux64-full-201611202210.tar.bz2 and the Source code (tar.gz) file, but I got some error message when running the ./configure command.
I'll try again and take better note of what happens.
Thanks, Mik
Posted : 22/11/2016 10:48 am
MrMik
(@mrmik)
I'm trying to install (in Ubuntu 16.04LTS) the Slic3r-1.31.6-prusa3d-linux64-full-201611202210 file, after extracting it from the Slic3r-1.31.6-prusa3d-linux64-full-201611202210.tar.bz2 file.
Downloading and extraction seem to work well, no error messages.
But the ./configure command results in the error message: bash: ./configure: No such file or directory
p@p-ThinkPad-T540p:~$ cd prusa-slic3r/
p@p-ThinkPad-T540p:~/prusa-slic3r$ tar xvjf Slic3r-1.31.6-prusa3d-linux64-full-201611202210.tar.bz2
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libtiff.so.5.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libjpeg.so.62
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_gl-3.0.so.0.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_html-3.0.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/liblzma.so.5.0.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_baseu-3.0.so.0.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libpng12.so.0.50.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_adv-3.0.so.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/building.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/hourglass.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/delete.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/package_green.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r_192px.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bullet_red.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/note.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/wrench.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/infill.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/shape_handles.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/page_white_go.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r_128px.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r.ico
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/shape_flip_horizontal.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r.icns
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_stop_blue.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/application_view_tile.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/spool.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/cog_go.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/plugin_go.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/printer_empty.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/film.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/package.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/brick_go.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_rotate_anticlockwise.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/plugin_add.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/disk.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/house.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/brick_delete.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/shape_ungroup.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bullet_blue.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bullet_black.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/joystick.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bullet_green.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_out.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/textfield.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_pause_blue.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/plugin.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/funnel.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_down.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_up.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/reslice.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/brick_add.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_play.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/cog.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/zoom.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_left.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bullet_white.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/box.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_right.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_stop.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/bricks.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/lorry_go.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/add.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/brick.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/cross.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/time.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/error.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_pause.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/arrow_rotate_clockwise.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r_192px_transparent.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/control_play_blue.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/Slic3r-console.ico
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/tag_blue.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/layers.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/var/lorry_add.png
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/slic3r.pl
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_core-3.0.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/perl5.22.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libjpeg.so.62.1.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_html-3.0.so.0.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_core-3.0.so.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_core-3.0.so.0.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/bin/libwx_gtk2u_adv-3.0.so.0.2.0
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/slic3r
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/AutoLoader.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/strict.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/B.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Exporter/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Exporter/Heavy.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Crypt/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Crypt/CBC.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/MultipleRings.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/FlowsnakeCentres.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/Base/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/Base/Digits.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/Base/Generic.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/Base/NSEW.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/ArchimedeanChords.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/SacksSpiral.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/HilbertCurve.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/OctagramSpiral.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath/Flowsnake.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/PlanePath.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/Complex.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/Trig.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Math/Libm.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/vars.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Config_git.pl
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Scalar/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Scalar/Util.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/MotionPlanner.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/SpiralVase.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/PressureRegulator.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/Reader.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/CoolingBuffer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GCode/ArcFitting.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/SupportMaterial.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/State.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/Simple.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/GCode.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print/Object.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Polyline.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Polygon.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/ExPolygon.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Config.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/ExtrusionPath.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Layer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Surface.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/OBJ.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/AMF.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/AMF/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/AMF/Parser.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Format/STL.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Geometry/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Geometry/Clipper.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Geometry.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/ObjectCutDialog.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/3DPreview.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/ObjectPartsPanel.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/OverrideSettingsPanel.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/2DToolpaths.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/ObjectSettingsDialog.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/2D.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater/3D.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Projector.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Notifier.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/ConfigWizard.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Tab.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/2DBed.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Plater.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/OptionsGroup/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/OptionsGroup/Field.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/ProgressStatusBar.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Controller.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/OptionsGroup.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/AboutDialog.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Controller/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Controller/PrinterPanel.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Controller/ManualControlDialog.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/SimpleTab.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/BonjourBrowser.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/Preferences.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/MainFrame.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/3DScene.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI/BedShapeDialog.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Point.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/XS.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Model.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/GUI.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Print.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/ExtrusionLoop.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Flow.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r/Line.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XSLoader.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Cwd.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Thread/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Thread/Queue.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Thread/Semaphore.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Config.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/File.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Socket/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Socket/UNIX.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Socket/INET.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Socket/IP.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Seekable.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Handle.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Socket.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO/Select.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/threads/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/threads/shared.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/warnings/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/warnings/register.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/re.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/warnings.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/overloading.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Exporter.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/HTTP/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/HTTP/Methods.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/Bonjour/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/Bonjour/Entry.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Resolver/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Resolver/UNIX.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Resolver/Base.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Resolver.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Text.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR/OPT.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR/SRV.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR/PTR.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR/TXT.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Header.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/DomainName.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Parameters.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Question.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/RR.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Domain.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Update.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS/Packet.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/HTTP.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/DNS.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Net/Bonjour.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/base.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Text/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Text/ParseWords.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Devel/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Devel/GlobalDestruction.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/constant.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Slic3r.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Carp.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Term/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Term/Cap.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Date.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Headers/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Headers/Util.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Config.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Request/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Request/Common.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Headers.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Request.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Status.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Message.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/HTTP/Response.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Unicode/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Unicode/Normalize.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Data/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Data/UUID.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/MediaTypes.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/Protocol.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/MemberMixin.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/UserAgent.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/Protocol/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP/Protocol/http.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Class/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Class/XSAccessor.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Class/XSAccessor/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Class/XSAccessor/Heavy.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Class/Accessor.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Carp/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Carp/Heavy.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Escapes.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple/BlackBox.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple/LinkSection.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple/TiedOutFH.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple/Transcode.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Text.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Simple.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Pod/Usage.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Tie/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Tie/Hash.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Tie/StdHandle.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Tie/Handle.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/POSIX.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/attributes.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/constant/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/constant/defer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Storable.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Getopt/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Getopt/Long.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/Config.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/Alias.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/Byte.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/Encoding.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/MIME/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/MIME/Name.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Encode/Locale.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/FindBin.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/Escape.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/_server.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/_generic.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/http.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI/_query.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/URI.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/mro.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/feature.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Digest/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Digest/base.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Digest/SHA.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Digest/MD5.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/integer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/App.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Grid.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Timer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Menu.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Wx_Exp.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Mini.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/GLCanvas.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Event.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Locale.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/DropSource.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Html.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/Print.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/DND.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx/RadioBox.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/bytes_heavy.pl
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Config_heavy.pl
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/LWP.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Method/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Method/Generate/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Method/Generate/Constructor.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Method/Generate/Accessor.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Method/Generate/BuildAll.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/lib.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Errno.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/overload/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/overload/numbers.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Time/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Time/Local.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Time/HiRes.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ExpatXS/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ExpatXS/Preload.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ExpatXS/Encoding.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ExpatXS.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ParserDetails.ini
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/ParserFactory.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/Base.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/XML/SAX/Exception.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/Exporter/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/Exporter/Progressive.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/Util.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/Defer.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Sub/Quote.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Symbol.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Growl/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Growl/GNTP.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/parent.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/List/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/List/Util.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Fcntl.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/OpenGL.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Role/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Role/Tiny.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/Spec/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/Spec/Unix.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/Glob.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/Basename.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/File/Spec.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/I18N/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/I18N/Langinfo.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/threads.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Wx.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Socket.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/SelectSaver.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/bytes.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/overload.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/locale.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Math/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Math/Libm/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Math/Libm/autosplit.ix
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Math/Libm/Libm.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Fcntl/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Fcntl/Fcntl.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Slic3r/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Slic3r/XS/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Slic3r/XS/XS.bs
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Slic3r/XS/XS.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/re/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/re/re.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/IO/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/IO/IO.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/threads/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/threads/shared/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/threads/shared/shared.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/threads/threads.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/B/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/B/B.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Unicode/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Unicode/Normalize/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Unicode/Normalize/Normalize.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Data/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Data/UUID/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Data/UUID/UUID.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Class/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Class/XSAccessor/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Class/XSAccessor/XSAccessor.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Encode/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Encode/Byte/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Encode/Byte/Byte.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Encode/Encode.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/POSIX/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/POSIX/POSIX.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/OpenGL/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/OpenGL/OpenGL.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Cwd/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Cwd/Cwd.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Digest/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Digest/SHA/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Digest/SHA/SHA.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Digest/MD5/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Digest/MD5/MD5.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Print/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Print/Print.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Grid/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Grid/Grid.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/DND/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/DND/DND.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/GLCanvas/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/GLCanvas/GLCanvas.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Html/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Html/Html.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Wx/Wx.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Storable/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Storable/Storable.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Socket/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Socket/Socket.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Time/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Time/HiRes/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/Time/HiRes/HiRes.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/XML/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/XML/SAX/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/XML/SAX/ExpatXS/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/XML/SAX/ExpatXS/ExpatXS.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/List/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/List/Util/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/List/Util/Util.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/File/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/File/Glob/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/File/Glob/Glob.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/I18N/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/I18N/Langinfo/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/I18N/Langinfo/Langinfo.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/mro/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/mro/mro.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/attributes/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/auto/attributes/attributes.so
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/DynaLoader.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Module/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Module/Runtime.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/utf8.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/IO.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/_strictures.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/_Utils.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/HandleMoose/
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/HandleMoose/_TypeMap.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/sification.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/_mro.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/Role.pm
Slic3r-1.31.6-prusa3d-linux64-full-201611202210/lib/site_perl/5.22.0/Moo/Object.pm
p@p-ThinkPad-T540p:~/prusa-slic3r$ ./configure
Posted : 22/11/2016 12:19 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
the Ubuntu story...
and rightly so. There is no configure.
Just run the slic3r from the place wherre you extracted it.
Posted : 23/11/2016 9:06 am
MrMik
(@mrmik)
the Ubuntu story...
Thank you Vojtech, I tried that, but something goes wrong. It looks familiar.
p@p-ThinkPad-T540p:~$ cd /home/p/prusa-slic3r/Slic3r-1.31.6-prusa3d-linux64-full-201611202210/
p@p-ThinkPad-T540p:~/prusa-slic3r/Slic3r-1.31.6-prusa3d-linux64-full-201611202210$ slic3r
Subroutine setenv redefined at /usr/share/perl5/Slic3r/Config.pm line 195.
Subroutine min_object_distance redefined at /usr/share/perl5/Slic3r/Config.pm line 352.
Subroutine apply_print_config redefined at /usr/share/perl5/Slic3r/GCode.pm line 32.
Subroutine set_extruders redefined at /usr/share/perl5/Slic3r/GCode.pm line 39.
Subroutine set_origin redefined at /usr/share/perl5/Slic3r/GCode.pm line 48.
Subroutine preamble redefined at /usr/share/perl5/Slic3r/GCode.pm line 62.
Subroutine change_layer redefined at /usr/share/perl5/Slic3r/GCode.pm line 76.
Subroutine extrude redefined at /usr/share/perl5/Slic3r/GCode.pm line 107.
Subroutine extrude_loop redefined at /usr/share/perl5/Slic3r/GCode.pm line 115.
Subroutine extrude_path redefined at /usr/share/perl5/Slic3r/GCode.pm line 240.
Subroutine travel_to redefined at /usr/share/perl5/Slic3r/GCode.pm line 352.
Subroutine needs_retraction redefined at /usr/share/perl5/Slic3r/GCode.pm line 389.
Subroutine retract redefined at /usr/share/perl5/Slic3r/GCode.pm line 424.
Subroutine unretract redefined at /usr/share/perl5/Slic3r/GCode.pm line 449.
Subroutine point_to_gcode redefined at /usr/share/perl5/Slic3r/GCode.pm line 459.
Subroutine set_extruder redefined at /usr/share/perl5/Slic3r/GCode.pm line 469.
Subroutine pre_toolchange redefined at /usr/share/perl5/Slic3r/GCode.pm line 514.
Subroutine post_toolchange redefined at /usr/share/perl5/Slic3r/GCode.pm line 542.
Subroutine wipe redefined at /usr/share/perl5/Slic3r/GCode.pm line 565.
Subroutine init_external_mp redefined at /usr/share/perl5/Slic3r/GCode.pm line 630.
Subroutine init_layer_mp redefined at /usr/share/perl5/Slic3r/GCode.pm line 635.
Subroutine travel_to redefined at /usr/share/perl5/Slic3r/GCode.pm line 640.
Unknown constructor for Slic3r::GCode already exists at /usr/share/perl5/Slic3r/GCode.pm line 13.
Compilation failed in require at /usr/share/perl5/Slic3r.pm line 47.
BEGIN failed--compilation aborted at /usr/share/perl5/Slic3r.pm line 47.
Compilation failed in require at /usr/bin/slic3r line 15.
BEGIN failed--compilation aborted at /usr/bin/slic3r line 15.
Posted : 23/11/2016 10:25 am
MrMik
(@mrmik)
The previous error message while trying the git approach looked similar:
p@p-ThinkPad-T540p:~/Slic3r$
Posted : 23/11/2016 10:27 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
you have to run
./lic3r
not
slic3r
The first one runs the one from the local directory. The other one runs slic3r from the system directory.
Posted : 23/11/2016 10:28 am
MrMik
(@mrmik)
you have to run
./lic3r
not
slic3r
Thank you for your patience, now it works!
Posted : 23/11/2016 11:48 am
MrMik
(@mrmik)
you have to run
./lic3r
not
slic3r
When I run the Prusa Slic3r 1.31.6 in Ubuntu as above, then the default infill is linear, not cubic.
Running the new Slic3r in Windows, cubic is the default infill (at least it was a few days ago).
Is this a deliberate change by Prusa staff or why is this happening? Do I need to check other settings as well? It's very tricky to do because I have to reboot into a different OS to compare the settings. 🙂
Posted : 24/11/2016 10:04 am
prusayo
(@prusayo)
Has anyone tried the new Slic3r Prusa edition 1.7.5? How is it?
http://prusaprinters.org/introducing-slic3r-prusa-edition/
Posted : 28/11/2016 5:43 pm
prusayo
(@prusayo)
For me the Layers tab is empty. I can no longer see any layers.
Posted : 28/11/2016 6:29 pm
prusayo
(@prusayo)
Why is the default horizontal solid layers 9 top and 7 bottom? Isn't that excessive?
Posted : 28/11/2016 6:34 pm
Wirlybird
(@wirlybird)
I found I had to run the slice first to get anything. Maybe it is just taking a really long time. Performance seems much slower on the most recent version.
Posted : 28/11/2016 6:40 pm
clayton.b
(@clayton-b)
Hi all!
Happy to be on here. Hope for this to be the first of many posts on the forum...
I'm printing with the new Slic3r settings and I noticed a little warping on one of my prints. I'm new to this, and was just curious about the PLA settings and why the heated bed is set to a default temperature of 55 degrees? I am reading all online how people are using 65 degrees plus! What's the advantages to having such a lower heatbed temp compared to what others use? Could this be the potential cause of my warping issues?
Thanks!
Posted : 29/11/2016 5:11 am
prusayo
(@prusayo)
Hi all!
Thanks!
Heated bed is so the filament sticks to the bed. Try lowering nozzle temperature to help prevent warping.
Posted : 29/11/2016 5:53 am
prusayo
(@prusayo)
Using final 1.7.5 can anyone create gcode for the large fractal pyramid (vase mode) here:
http://www.thingiverse.com/thing:1356547
I am saving for over an hour and it's not done. There seems to be a significant slowness with this slic3r.
Posted : 29/11/2016 5:55 am
Wirlybird
(@wirlybird)
I'll try it this evening and report back.
I though it seemed the slicer was slower but wasn't sure.
Posted : 29/11/2016 12:58 pm
Wirlybird
(@wirlybird)
Hi all!
Thanks!
I use the defaults for the bed and it is fine. Warping with PLA from the bed will primarily be from bad adhesion to the bed which is dirty surface or bad first layer height.
Also make sure the area isn't drafty or to cold.
PLA extrusion temps of 190-210 is usually a good range.
Posted : 29/11/2016 1:02 pm
Wirlybird
(@wirlybird)
I am going 45 minutes slicing on this and I am on a very powerful computer. This is unusable. S3D sliced this in about 2 minutes.
Posted : 30/11/2016 2:45 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
The fractal pyramid is a one of a hell complex object. Indeed, the fractals have an infinite complexity by definition. This model and the various chain fabrics are a benchmark for slicer optimization, but they are not what the most people print. It is true, that Slic3r has not been optimized for such models and it is on my list.
Posted : 30/11/2016 9:19 am
Yury
 Yury
(@yury)
Thank you PRUSA Team!
Can you help me please - could not find any 0.15 settings 😥
Posted : 30/11/2016 11:44 am
Page 3 / 5
