Disabling the repetitive beeping on ColorPrint color changes
Martin Majewski
(@martin-majewski)
Hello everyone,
Is there a way to disable the repetitive beeping when the filament change has to be performed during layer based ColorPrints?
One time beeping or a short beep-pattern would be enough and not that annoying for the surrounding people. 🙂
Less stress at work is always great.
Best Regards,
Martin
-- www.martinmajewski.net --Printables:printables.com/@MartinMajewski
Thingiverse:thingiverse.com/MartinMajewski
BlueSky:martinmajewski.bsky.social
Veröffentlicht : 11/10/2016 4:22 pm
alexander.f
(@alexander-f)
Re: Disabling the repetitive beeping on ColorPrint color changes
+1 for that
angry wife unhappy life 😉
Veröffentlicht : 07/12/2016 11:13 am
PJR
 PJR
(@pjr)
Antient Member Moderator
You could remove the beeper from the LCD panel. But I don't think you can do it with GCode...
Peter
Veröffentlicht : 07/12/2016 12:16 pm
bluetac in the sounder opening, works wonders!
had this problem with a desk top server!
regards Joan!
Veröffentlicht : 07/12/2016 1:41 pm
geoffrey compagnon
(@geoffrey-compagnon)
A more elegant solution would be to amend the firmware a tad. The beeping routing is located in Marlin_main.cpp, from line 4480 to 4496.
You would essentially comment out this section:
SET_OUTPUT(BEEPER);
if (counterBeep== 0){
WRITE(BEEPER,HIGH);
if (counterBeep== 20){
WRITE(BEEPER,LOW);
You could go further and change it to this
#ifdef M600_BEEP
SET_OUTPUT(BEEPER);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,LOW);
#endif
And add/comment out
#define M600_BEEP
in configuration.h to enable/disable it.
Veröffentlicht : 07/12/2016 1:55 pm
