					                		Dimafix on a PEI Sheet ? - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/</link>
                <lastBuildDate>Wed, 10 Jun 2026 18:12:13 +0000</lastBuildDate>
                        <title>RE: Dimafix on a PEI Sheet ?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-223938</link>
                        <pubDate>Sun, 21 Jun 2020 10:44:13 +0000</pubDate>
                        <description><![CDATA[3D Printer Adhesive Glue by Layerneer, the Magigoo Pen, and Dimafix all work well.  Even a simple glue stick will work.  As said above, they will promote adhesion without hindering removal. ...]]></description>
                        <content:encoded><![CDATA[<p class="a-size-large a-spacing-none"><span class="a-size-large"><a href="https://www.amazon.com/Magigoo-Pen-All-One-Adhesive/dp/B01N2JGTWJ/ref=as_li_ss_tl?dchild=1&amp;keywords=bed+printer+adhesion&amp;qid=1592734396&amp;sr=8-2&amp;linkCode=ll1&amp;tag=chuckh1967-20&amp;linkId=88c452bb1f2ce7a0eb6b21fde043f47e&amp;language=en_US" target="true">3D Printer Adhesive Glue by Layerneer</a>, the <a href="https://www.amazon.com/Magigoo-Pen-All-One-Adhesive/dp/B01N2JGTWJ/ref=as_li_ss_tl?dchild=1&amp;keywords=bed+printer+adhesion&amp;qid=1592734396&amp;sr=8-2&amp;linkCode=ll1&amp;tag=chuckh1967-20&amp;linkId=88c452bb1f2ce7a0eb6b21fde043f47e&amp;language=en_US" target="true">Magigoo Pen</a></span><span id="productTitle" class="a-size-large">, and <a href="https://www.matterhackers.com/store/l/dimafix-3d-printing-adhesive-pen/sk/MR0VKNJY?rcode=GAT9HR&amp;item_group_id=PG_MR0VKNJY&amp;rcode=PPCADS&amp;gclid=EAIaIQobChMI6Z3cld2S6gIVS77ACh0U_QH8EAAYASAAEgLijvD_BwE" target="true">Dimafix</a> all work well.  Even a <a href="https://www.amazon.com/Printer-Aokin-Stickers-Filament-Platform/dp/B07PH6ZQTC/ref=as_li_ss_tl?dchild=1&amp;keywords=bed+printer+adhesion&amp;qid=1592734396&amp;sr=8-4&amp;linkCode=ll1&amp;tag=chuckh1967-20&amp;linkId=dee588e54202dca82de56a8940437652&amp;language=en_US" target="true">simple glue stick</a> will work.  As said above, they will promote adhesion without hindering removal. There are more options such as hair spray. <a href="https://3dgbire.com/products/dimafix-can1?variant=30398170890293" target="true">Dimafix is also available in a can</a> in Europe.  I have never tried it.  I suspect it works like <a href="https://www.amazon.com/Extra-Super-Professional-Spray-Unscented/dp/B00908551C/ref=as_li_ss_tl?dchild=1&amp;keywords=aquanet&amp;qid=1592736180&amp;sr=8-3&amp;linkCode=ll1&amp;tag=chuckh1967-20&amp;linkId=ae109e7d3590bc8977ca4f4fac8a0ee7&amp;language=en_US" target="true">Aquanet</a>.  Aquanet works well because it is easy to get a thin uniform surface.   </span></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-223938</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-223909</link>
                        <pubDate>Sun, 21 Jun 2020 08:01:13 +0000</pubDate>
                        <description><![CDATA[Dimafix works like hell. I had always problems with ABS on my MK2S, with Dimafix nothing lifts and warps and the thing is easily washable by water. The surface does not get damaged chemicall...]]></description>
                        <content:encoded><![CDATA[<p>Dimafix works like hell. I had always problems with ABS on my MK2S, with Dimafix nothing lifts and warps and the thing is easily washable by water. The surface does not get damaged chemically but unfortunately the adhesion is now actually too much, I just damaged the PEI layer trying to remove a print :( And yes, the bed was completely room temperature.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>numo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-223909</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215642</link>
                        <pubDate>Mon, 18 May 2020 16:59:38 +0000</pubDate>
                        <description><![CDATA[I have used MagiGoo and similar adhesion enhancers on my PEI. The PEI has not been damaged from this, but it does require a thorough clean. If you&#039;re going to be switching between materials,...]]></description>
                        <content:encoded><![CDATA[<p>I have used MagiGoo and similar adhesion enhancers on my PEI. The PEI has not been damaged from this, but it does require a thorough clean. If you're going to be switching between materials, I'd dedicate a separate (perhaps damaged) PEI surface for that purpose and keep a near-pristine PEI surface for normal PLA or PETG printing. I've got a "hot &amp; sticky" PEI sheet I used any time I'm using high temp materials.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>bobstro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215642</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215640</link>
                        <pubDate>Mon, 18 May 2020 16:38:44 +0000</pubDate>
                        <description><![CDATA[Posted by: @denial84 Hi man!I have a problem to print ABS ..... if I not use glue stick on a pei the corner of the models lift up :(I have found Dimafix product ! What you think about? It&#039;s ...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2471" data-postid="32215" data-mention="denial84"><div class="wpforo-post-quote-author"><strong> Posted by: @denial84 </strong></div><p>Hi man!<br />I have a problem to print ABS ..... if I not use glue stick on a pei the corner of the models lift up :(<br />I have found Dimafix product ! What you think about? It's safe for PEI surface?<br />Someone have use it?<br />Tnx man!</p></blockquote><p>When I use glue, e.g. for nylon, i always use Dimafix. You have to apply it on the cold bed and it will stick from about 50 degrees Celsius. After printing and cooling the bed you can rinse the glue with water. This will not destroy the PEI film.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>karl-herbert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215640</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215625</link>
                        <pubDate>Mon, 18 May 2020 15:05:22 +0000</pubDate>
                        <description><![CDATA[Hi, I&#039;ve used dimafix on the latest 3 prints on my smooth PEI sheet with ABS, without seeing any apparent damage to the plate so far.]]></description>
                        <content:encoded><![CDATA[<p>Hi, I've used dimafix on the latest 3 prints on my smooth PEI sheet with ABS, without seeing any apparent damage to the plate so far.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Emanuele I</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-215625</guid>
                        <title>Dimafix on a PEI Sheet ?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-32215</link>
                        <pubDate>Wed, 10 May 2017 23:34:10 +0000</pubDate>
                        <description><![CDATA[Hi man!
I have found Dimafix product ! What you think about? It&#039;s safe for PEI surfac...]]></description>
                        <content:encoded><![CDATA[Hi man!<br/>
I have a problem to print ABS ..... if I not use glue stick on a pei the corner of the models lift up :(<br/>
I have found Dimafix product ! What you think about? It's safe for PEI surface?<br/>
Someone have use it?<br/>
Tnx man!]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>SmalLabs.net</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/dimafix-on-a-pei-sheet/#post-32215</guid>
