					                		Creating a spare SD card - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/</link>
                <lastBuildDate>Sat, 16 May 2026 21:14:58 +0000</lastBuildDate>
                        <title>RE: Creating a spare SD card</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216354</link>
                        <pubDate>Thu, 21 May 2020 14:51:32 +0000</pubDate>
                        <description><![CDATA[I have had the best luck using the SD Memory Card Formatter software from the SD Association.]]></description>
                        <content:encoded><![CDATA[<p>I have had the best luck using the <a href="https://www.sdcard.org/downloads/formatter/" target="true">SD Memory Card Formatter</a> software from the SD Association.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>bobstro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216354</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216326</link>
                        <pubDate>Thu, 21 May 2020 11:11:29 +0000</pubDate>
                        <description><![CDATA[Hello I had the same problem as you when formatting with a specialized software under Mac and and it did not work I tried with the Microsoft format of the finder and there it works, I now us...]]></description>
                        <content:encoded><![CDATA[<p>Hello I had the same problem as you when formatting with a specialized software under Mac and and it did not work I tried with the Microsoft format of the finder and there it works, I now use an SD card of 128 giga without problem</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Tankhub</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216326</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216325</link>
                        <pubDate>Thu, 21 May 2020 11:11:12 +0000</pubDate>
                        <description><![CDATA[Posted by: @michal-o_1551621334 HelloI need to create a spare SD cardI used sandisk formated as fat32 and the printer does not recognise it.I see the SD card inserted message but in menu the...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="6318" data-postid="19718" data-mention="michal-o_1551621334"><div class="wpforo-post-quote-author"><strong> Posted by: @michal-o_1551621334 </strong></div><p>Hello<br />I need to create a spare SD card<br />I used sandisk formated as fat32 and the printer does not recognise it.<br />I see the SD card inserted message but in menu the is a no sd card message. Empty folder with no file although but i copied a gcode file on it earlier.<br />How do i prepare a sd card so it is recognized by mk2</p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-216325</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-215740</link>
                        <pubDate>Mon, 18 May 2020 22:27:59 +0000</pubDate>
                        <description><![CDATA[@william-h14Thank you for this hint! I was having problems with my 32 Sd card not showing up on the printer but after formatting it on my laptop with the quick format box unchecked, it worke...]]></description>
                        <content:encoded><![CDATA[<p>@william-h14</p><p>Thank you for this hint! I was having problems with my 32 Sd card not showing up on the printer but after formatting it on my laptop with the quick format box unchecked, it worked!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>tedwards</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-215740</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-174718</link>
                        <pubDate>Wed, 20 Nov 2019 08:22:05 +0000</pubDate>
                        <description><![CDATA[HiFAT32 should work without any issue. Just checked a spare SD 4GB card standardly formatted for FAT32.What is the size of your SD card?Check please your g-code file extension is correct.]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>FAT32 should work without any issue. Just checked a spare SD 4GB card standardly formatted for FAT32.</p><p>What is the size of your SD card?</p><p>Check please your g-code file extension is correct.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Zoltan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-174718</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-174710</link>
                        <pubDate>Wed, 20 Nov 2019 06:50:28 +0000</pubDate>
                        <content:encoded><![CDATA[<blockquote data-userid="6318" data-postid="19718" data-mention="michal-o_1551621334"><div class="wpforo-post-quote-author"><strong> Posted by: @michal-o_1551621334 </strong></div><p>Hello<br />I need to create a spare SD card<br />I used sandisk formated as fat32 and the printer does not recognise it.<br />I see the SD card inserted message but in menu the is a no sd card message. Empty folder with no file although but i copied a gcode file on it earlier.<br />How do i prepare a sd card so it is recognized by mk2</p></blockquote><p><span data-sheets-value="{&quot;1&quot;:2,&quot;2&quot;:&quot;Am facing the same issue  someone help me out.&quot;}" data-sheets-userformat="{&quot;2&quot;:513,&quot;3&quot;:{&quot;1&quot;:0},&quot;12&quot;:0}">I am facing the same issue someone help me out.</span></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>mogh.m</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-174710</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-162755</link>
                        <pubDate>Wed, 11 Sep 2019 03:07:06 +0000</pubDate>
                        <description><![CDATA[Not sure if anyone is still having this issue but I was able to get my printer to read my card, 64 gb sandisk, by reformatting it as a FAT32. To format it as this I found a nice piece of fre...]]></description>
                        <content:encoded><![CDATA[<p>Not sure if anyone is still having this issue but I was able to get my printer to read my card, 64 gb sandisk, by reformatting it as a FAT32. To format it as this I found a nice piece of free software, link below, that formats any size drive as FAT32. When you follow the link, click "Windows GUI version of fat32format" then click the picture and run the software. So far I have tested this on 4 new 64 gb SD cards by sandisk and all have worked.</p><p><a href="http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm">http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm</a></p><p>Happy Printing!!!!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>Garrett Klein</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-162755</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-156796</link>
                        <pubDate>Sun, 04 Aug 2019 05:54:29 +0000</pubDate>
                        <description><![CDATA[I had issues, with the card reader not working.  Turns out the size of the card was the issue.  64 GB, no go.  32, worked fine.]]></description>
                        <content:encoded><![CDATA[<p>I had issues, with the card reader not working.  Turns out the size of the card was the issue.  64 GB, no go.  32, worked fine. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>KiwiB</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-156796</guid>
                        <title>Re: Creating a spare SD card</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-121603</link>
                        <pubDate>Mon, 24 Dec 2018 02:22:14 +0000</pubDate>
                        <description><![CDATA[I was having this issue. Finally I formatted the SD Card (FAT32) with the &quot;Quick Format&quot; UNCHECKED and that worked!!]]></description>
                        <content:encoded><![CDATA[I was having this issue. Finally I formatted the SD Card (FAT32) with the "Quick Format" <B>UNCHECKED</B> and that worked!!]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>HoldenArt - William</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-121603</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-27253</link>
                        <pubDate>Wed, 08 Mar 2017 20:28:59 +0000</pubDate>
                        <description><![CDATA[:? hi guys, have you ever calculated how many *.gcode files you could store on such big sd-cards ???
Indeed, but the bundled in card is 8GB. :D
 :roll: it&#039;s going to be very confusing if ...]]></description>
                        <content:encoded><![CDATA[<QUOTE author="JeffJordan">:? hi guys, have you ever calculated how many *.gcode files you could store on such big sd-cards ???</QUOTE>
Indeed, but the bundled in card is 8GB. :D<br/>
<QUOTE author="JeffJordan"> :roll: it's going to be very confusing if you store 50 or more *.gcode files at a single sd-card when you try to navigate through it, using the little lcd console.</QUOTE>
Folders!<br/>
I put the bundled Gcode files into their own folders, then I have a folder for calibration files (eg. v2calibration, 1st layer calibration - similar to yours -, etc), and an Archive folder for Gcode that I may want to print again in the future (eg. I have some modular objects where I can print more pieces if I need too).]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>gabriele.s2</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/creating-a-spare-sd-card/#post-27253</guid>
