Constant Reset
chris.m5
(@chris-m5)
Constant Reset
I have a I3 and for some reason over the last week it has started resetting every time I try and heat my bed. I would normally heat the bed so I could clean it but now every time I try this is what I get.
Settings -> Extruder -> Bed Temp
It starts at 0 and when I turn the dial it goes to 30 degrees and the LCD jumps back to the III screen and main menu...
Any ideas on why or how to fix this?
Postato : 30/12/2016 5:28 pm
Re: Constant Reset
Hi Chris,
isn't it
Settings
Temperature
Bed:
does it work ok if you preheat for PLA?
if so, would that work whilst you look for a solution?
regards Joan.
Postato : 30/12/2016 6:53 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Constant Reset
Chris
Which version i3 do you have? What is the controller board?
Peter
Postato : 30/12/2016 9:38 pm
