					                		Color Printing with MK2S: very easy but... - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/color-printing-with-mk2s-very-easy-but.../</link>
                <lastBuildDate>Sun, 17 May 2026 21:10:22 +0000</lastBuildDate>
                        <title>Color Printing with MK2S: very easy but...</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/color-printing-with-mk2s-very-easy-but.../#post-46283</link>
                        <pubDate>Thu, 16 Nov 2017 17:43:40 +0000</pubDate>
                        <description><![CDATA[I had a quick look printing in 2 colors a very simple object. I installed the latest PrusaControl (0.9.4_415_beta), imported the STL model, generate the G-code, set the Z-height of the filam...]]></description>
                        <content:encoded><![CDATA[I had a quick look printing in 2 colors a very simple object. I installed the latest PrusaControl (0.9.4_415_beta), imported the STL model, generate the G-code, set the Z-height of the filament change and save the G-code. So far so good.<br/>
By the way, the app. just adds the M600 command at the "right" place.<br/>
Copied the file to the SD card and started the process of printing.<br/>
The printer is in a room where the door is normally closed. I was "called" by the filament change. I barely heard the sound. Maybe other frequencies could be used because you can fall asleep next to the door and you won't hear anything :-)<br/>
I guess this is something to change in the firmware as it is repeated until you actually change the filament.<br/>
Anyway, a new filament was correctly inserted but unfortunately the LCD display was "covered" with meaningless characters.<br/>
I knew by experience I had just to click on the button to confirm the change.<br/>
Are there any problems with the serial port? I am running Firmware: 3.0.12<br/>
Another thing I noticed: Just before moving quickly back to the object, the extruder spits another 2-3 cm of filament.<br/>
You have to be quick to remove it with a tweezer before it's above the object. You really cannot sleep...<br/>
Is it as well related to my firmware?<br/>
Anyway, I had some fun color printing.<br/>
Thanks]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/">Others (Archive)</category>                        <dc:creator>walter.v4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/color-printing-with-mk2s-very-easy-but.../#post-46283</guid>
