Can't pass calibration
ryan.f15
(@ryan-f15)
Hi everyone. I've done everything I can here I think. I'm always getting this:
"XYZ calibration failed. Bed Calibration point was not found"
But both sides are at 100mm and the sensor is in the little circle. Everything is level. What should I do?
Posted : 17/01/2018 4:50 am
BillC
(@billc)
Re: Can't pass calibration
Check the height of your PINDA probe. It should be less than 1mm above the tip of the extruder nozzle - ideal initial setting is between 0.4mm and 0.7mm above the nozzle tip.
Do you see a lit LED on top of the probe and does the LED go out if you hold a screwdriver blade under the probe?
Bill
Tagaytay City, Philippines
Posted : 17/01/2018 4:17 pm
ryan.f15
(@ryan-f15)
Yes. I tested it. Why would it do this on the third point only if it found the first two?
Posted : 17/01/2018 5:16 pm
BillC
(@billc)
Have a look at this thread and see if it helps you.
https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/is-my-pinda-broken-because-it-deforms--t5762-s10.html
or this one
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/problem-with-%E2%80%9Acalibrate-xyz%E2%80%98-t12361.html#p55047
Bill
Posted : 18/01/2018 3:14 pm
ryan.f15
(@ryan-f15)
Ok well flashing down the FW at least gets me through the initial calibration points. Now I get a new error:
"XYZ Calibration compromised. Left Front Calibration point not reachable"
Posted : 20/01/2018 5:41 am
alexander.s27
(@alexander-s27)
http://help.prusa3d.com/l/en/article/zQeBMm2y6a-xyz-compromised-failed
Posted : 20/01/2018 7:59 am
ryan.f15
(@ryan-f15)
Thanks. I tried flashing the new firmware, now I can't even get it to find the first calibration point...:(
Posted : 21/01/2018 4:29 am
ryan.f15
(@ryan-f15)
Oh, and when I go to config, the PINDA sensor is directly centered in the front left calibration circle.
Posted : 21/01/2018 4:35 am
