Are we able to use the mk3 extruded body parts for the mk2s to fit the Noctua fan?
Metal
(@metal)
Question
Posted : 19/01/2018 5:09 am
Andreas Balogh
(@andreas-balogh)
Re: Are we able to use the mk3 extruded body parts for the mk2s to fit the Noctua fan?
I second the question.
Posted : 24/02/2018 10:52 am
AJS
 AJS
(@ajs)
I do not know the answer to your question - I have not looked at the MK3 parts.
However there many options for mounting a Noctura to a MK2 here:
https://shop.prusa3d.com/forum/improvements-f14/extruder-fan-specification--t1524.html
Posted : 24/02/2018 5:36 pm
digibluh
(@digibluh)
No, it's made for the bond-tech gears and filament sensor. you could probably omit the sensor but the gears no.
Posted : 25/02/2018 7:15 am
Colin
(@colin-4)
This worked for me.
https://www.thingiverse.com/thing:1827477
Posted : 26/02/2018 1:06 pm
Andreas Balogh
(@andreas-balogh)
Here's another candidate: https://www.thingiverse.com/thing:2726409
Allows to use the 40mm Noctua, but keeps all the other Mk2 Extruder parts otherwise.
I will try to build it when my ABS and PET filament has arrived.
Posted : 01/03/2018 8:38 pm
Andreas Balogh
(@andreas-balogh)
I've created a SCAD file merging the Mk3 Noctua hotend and the Mk2 extruder assembly (attached). The filament moves 2mm forward which may be compensated by recalibrating the origin - potentially by readjusting the x axis threaded rod screws connecting the frame.
Posted : 04/03/2018 10:08 pm
