After Build Question
mateo.d
(@mateo-d)
Hello,
I had a quick question becuase im worried that i build the i3 mk2s wrong.
After building it carefully and following all the steps i turned it on and the led screen was not on so i cant see anything. If the screen is not on what would the problem be. Also, I tried pressing buttons to see if anything happens but a loud noise appeared and had to turn it off.
Hope you can help,
Kind regards,
M
Posted : 01/02/2018 7:47 am
rob.l6
(@rob-l6)
Re: After Build Question
Where do you think the loud noise appeared?
Posted : 01/02/2018 7:54 am
mateo.d
(@mateo-d)
I guess the noise would come from the LED
Posted : 01/02/2018 8:17 am
AJS
 AJS
(@ajs)
I am guessing you have miss wired the connections between the LED and the RAMBO Board (the ribbon cables). Double check those.
Posted : 02/02/2018 5:50 am
The cable colour code is confusing. It is easy to get the rambo end upside down or swapped cable 1 to cable 2...
Regards Joan
Posted : 02/02/2018 1:33 pm
