3D print movement on Y axis
Pablo Reyes
(@pablo-reyes)
Thanks for the help.
I have a problem, I bought the printer assembled about 3 months ago, I printed several pieces and everything had worked well.
In my last impressions, I begin to have a problem, during the printing, approximately in the middle, the layers move and the impression is continued with offset on the Y axis (hot bed), it is variable in each impression. The first layer is always correct and the impression is not separated from the bed.
I do not know if it's a problem with the G-CODE, or with the printer. I did a self-test and calibrated the printer again, but the problem continues.
I have been using prusacontrol software, (I have been using it for 3 months, and I have never given that problem). With PLA Colorfabb material.
I have used it with different configurations, layer thicknesses, print sizes, and in all the same error occurs.
Posted : 30/09/2017 3:57 pm
AJS
 AJS
(@ajs)
Re: 3D print movement on Y axis
Check out the "Print suddenly shifts in X or Y and keeps printing." section here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
After checking those items, if you still have issues, let us know and we can help.
Posted : 30/09/2017 5:29 pm
Knickohr
(@knickohr)
Member Moderator
You have tighten your belt(s) too much and now the belts are stretching. Check it !
Thomas
Posted : 01/10/2017 9:25 pm
