Monoplexer and Multiplexer Redesigns (no metal parts required)
Página 4 / 4
Chadn55
(@chadn55)
Re: Monoplexer and Multiplexer Redesigns (no metal parts required)
Couldn't agree with you more, My MK2S was flawless before this upgrade. I have had nothing but problems with the MM and its always random different problems. Looking back, I wish I wouldn't have purchased it without reading the forums more. The whole design creates nothing but potential jams along the way. I'm pretty disappointed with the whole thing. I feel like Prusa really needs to fix the issues with this because there seems to be a few common themes.
Respondido : 01/02/2018 1:15 am
morten.e2
(@morten-e2)
Any chance you would be so nice and make a 6 way version of this one,
should be possible if you make it a bit longer and wider at the top part ?
Have seen a 9 way on a Italian site, that one was not for the prusa mmu and no files available for it...
Would be really nice 🙂
Very good work Seth, thanks 🙂
Respondido : 03/02/2018 5:14 pm
bainville.a
(@bainville-a)
Sorry to ping you, but I'm waiting patiently for the threaded version of your monoplexer and multiplexer.
Can you have time to release it soon ?
Thank you.
Respondido : 19/02/2018 5:45 pm
BunchaHooey
(@bunchahooey)
I think ABS would be fine, probably preferable.
Just remember that the break in may last longer due to the more durable material and the feed paths may take a little more initial coaxing with ABS filament.
Has anyone tried vapor smoothing an abs print to reduce/eliminate the break in period? If not, I'll try this and see how it works.
Respondido : 22/02/2018 7:00 pm
ntdesign
(@ntdesign)
No, but I found it wasn't necessary. Just take a bit of ABS filament that has been run through the gears and has bite marks, then run it through all the channels for a minute in a sawing motion. After about an hour printing on each channel I only saw very minor improvements over time. Trying to speed this up isn't worth it.
Respondido : 23/02/2018 11:30 am
ppaukstelis
(@ppaukstelis)
I have had far few jams/blockages with my MMU recently, but I decided to give this design a try. Just because I already had a printer with a 0.15 mm nozzle installed I printed it at 0.05 mm. 😛 . Looks nice and channels were very smooth to begin with. Just started an 11 hour print with it, so we'll see how it goes! All good after the first 6 filament swaps.
Respondido : 23/02/2018 10:12 pm
t0ffluss
(@t0ffluss)
First time poster, long time lurker 🙂 I must admit, this mod fixed all my MMU issues. I've only had successful prints since I swapped out the multiplexer with this one. Prusa should start paying seth.g2 for his services! Thank you! 😎
I only have one comment on the design, add 4 "facets" to allow the festo connectors to properly seat against the multiplexer. The flat surface doesn't do this MMU upgrade the justice it definitely deserves! 🙂
Respondido : 27/02/2018 7:30 am
Hannes
(@hannes-3)
Same here, my success rate went from 0 to 100% in an instant. Thanks!
Respondido : 21/03/2018 1:00 am
t0ffluss
(@t0ffluss)
any chance you could post the design file?
Respondido : 02/04/2018 7:24 pm
Asraff Amzani
(@asraff-amzani)
I've made few modifications of his mmu jig which has chamfered entrance and included a wider channel so the filament won't get stuck during loading at the entrance and smooth filament travel inside.
Gonna try it out for real when I got the time to swap the mmu jig.
https://www.thingiverse.com/thing:2849819
Respondido : 04/04/2018 10:05 am
Página 4 / 4
