Slic3r single material prints not unloading filament when done
I'm using Slic3r MM edition, latest release version 1.37.1. When I print a multi-material print, at the end the last used filament is retracted up into the metal tube and this is working fine. However when I use the same version of Slic3r with the same printer & same print settings (still set to multi-material mode), but the print uses only a single filament, it does not retract that filament at the end of the print. I have to manually unload it.
Is there a setting I might be missing?
Thanks.
Posted : 02/11/2017 7:08 pm
