Printer stopping during first layer
KaleidoRobo
(@kaleidorobo)
Okay, so I just finished putting together my MM upgrade, did all the calibrations including the first layer live adjust Z. Everything went fine. But when I generated my own gcode (using Prusa Control), the printer would start printing then hang up, moving to the front of the bed and just sitting there at temperature.
The first gcode I didn't have PrusaControl in single material mode. When it stopped, the lcd read 'tif' where the file name should have been. If I pressed the control nob a few times, the printing would resume the print, but without extruding anything.
I generated the code again in single material mode and the results were similar... See attached images.
Any clue what's going on?
Posted : 19/12/2017 11:07 pm
KaleidoRobo
(@kaleidorobo)
Re: Printer stopping during first layer
Update: I generated gcode for the same object in Prusa Slic3r and it printed fine. So apparently something went wrong with the code generated by PrusaControl.
Posted : 21/12/2017 12:55 pm
Sebastian650
(@sebastian650)
Are printing over USB or from SD card? Especialy when printing from SD card quite some people seems to manage it somehow to get incomplete gcodes quite often, maybe due to not properly removed SD card before removing them from the PC. Check the gcode that has failed, maybe you find something there.
Posted : 21/12/2017 5:50 pm
