Multimaterial/MK2/MK2S
cyrille.p
(@cyrille-p)
Hello, I've just received my Multimaterial upgrade 😀 (and my MK2S upgrade)
I own a MK2. I've read the MMU manual and it seems you can upgrade directly from MK2 to MMU. But as I've got my MK2/S upgrade now, what is the best to do ? upgrading first to MK2/S then MMU ? upgrading directly from MK2 to MMU ?
Thanks for your answers.
My youtube channel about the Prusa I3 MK2 https://www.youtube.com/channel/UCz-zQZcKcvEDdd9C9hOKYWg
Veröffentlicht : 30/09/2017 4:34 pm
AJS
 AJS
(@ajs)
Re: Multimaterial/MK2/MK2S
That is completely up to you.
I was in the same situation.
I choose to go straight to the MMU and keep the /S parts for spares, but I was having no issues with movement along my rods or the linear bearings. If I felt they were noisy or rubbing, I would have done the /S first.
You would not need to print all the /S parts - as some are replaced by MMU parts.
Veröffentlicht : 30/09/2017 5:22 pm
cyrille.p
(@cyrille-p)
Ok understood, thank you aaron.
Do you know what are the /S parts I need to print (to avoid printing parts that will be replaced by MMU parts?
Veröffentlicht : 30/09/2017 7:23 pm
AJS
 AJS
(@ajs)
The extruder body is the only one I can think of. (The part that holds the PINDA sensor).
Veröffentlicht : 30/09/2017 7:45 pm
