multi material and 0.25mm
patryk.c2
(@patryk-c2)
Hello guys,
I have been thinking of getting multi material upgrade for christmas. I print alot using 0.25 nozzle and i was wondering if i could use the multimaterial upgrade with this option ? if not then how difficult is it to change between the two ?
Thank you
Publié : 01/12/2017 12:12 am
AJS
 AJS
(@ajs)
Re: multi material and 0.25mm
You may want to search the forum...
https://shop.prusa3d.com/forum/original-prusa-i3-mk2-multi-material-f26/has-anyone-tried-using-a-0-25-nozzle-on-mm--t6687.html
Switching back and forth between MMU and original is not an easy switch, and I would not recommend it. Put it one way or the other, calibrate it, and keep it there.
Publié : 01/12/2017 3:42 am
