Ligament management
bert.v6
(@bert-v6)
Ligament management
Now the ligament spools are parked in the cradles, the ligaments get kind of tangled with the x-axis spiral wrap.
How do you deal with that?
Opublikowany : 19/11/2017 11:11 pm
Re: Ligament management
hi Bert,
I have my filament reels on a shelf with ptfe tube guiding the filament to the extruders, see the pictures below
there is a break in the bowden to prevent back feeding causing the filament to come off the reel sides and tangling
Opublikowany : 20/11/2017 1:03 am
bert.v6
(@bert-v6)
Hi Joan,
That is a nice idea.
I thought the filament is hygroscopic.
Is there no need to store the spools in a container?
Opublikowany : 20/11/2017 4:55 pm
ir_fuel
(@ir_fuel)
Not needed for simple PLA.
PVA, that's a different story.
Opublikowany : 20/11/2017 8:40 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Ideally, you should store it sealed with silica gel, but you will be OK without for a few weeks. PLA will "go off" when it gets damp; it's quite obvious when this happens. The extrusion will become a little porous and the temps will need increasing.
Peter
Opublikowany : 20/11/2017 8:43 pm
bert.v6
(@bert-v6)
I have more or less folowwed Joans idea. I have the spools on a shelve under the printer.
But, the PTFE with the filaments inside, still mess up with the spiral wrap.
@PRUSA, there must be a beter way do deal with this?
Opublikowany : 29/11/2017 4:58 pm
ntdesign
(@ntdesign)
A guy on thingiverse had this brilliant idea:
https://www.thingiverse.com/thing:2483029
I made myself one of those (and added a few alu strips to stabilize). It works very well, the filament is fed slightly above the wire harness.
Opublikowany : 29/11/2017 9:38 pm
