Enclosure for MM
I'd been waiting on the MM upgrade before building an enclosure for my printer. Finally have had time to put it together. It's a cube of acrylic sheets, fixed and supported using printed PLA corners and supports. The top and front are removable and held in place using magnets. In use, I usually just remove the front piece, but removing the top is useful if I have problems. There's extra supports at the front to keep the structure solid. To make it easy to feed filament into the extruders, I ran bowden tubes through a printed "pass-through" piece on the back of the printer (which is also used to feed in the power). I've included a few photos (and I'll write up the build here: https://hackaday.io/project/26133-original-prusa-i3-mk2-mm-enclosure )
Re: Enclosure for MM
And I realize people with enclosure printing know this, but I was surprised at the difference when printing ASA. This is a little test Lego brick I printed in Rigid Ink ASA, the left brick was printed with the enclosure, the right brick without (everything else the same).
nice looking box.
did you test if the bowden tubes interfere with the "lid" when you print tall objects?
Well the tubes certainly do get pressed up against the lid, but not in a way which appears to restrict the filament movement (thankfully! I hadn't checked because I tend not to print very tall stuff).
What settings are you using for the Rigid.Ink ASA?
Just curious as I am experiencing my Rigid.Ink ASA models curling off the bed.
100C for the bed, 250 for the hotend. No cooling. I've not tried anything big, but the small stuff stayed stuck with the enclosure.
