					                		Problems with PVA PrimaSelcet retraction - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/</link>
                <lastBuildDate>Mon, 13 Apr 2026 10:47:18 +0000</lastBuildDate>
                        <title>RE: Problems with PVA PrimaSelcet retraction</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225856</link>
                        <pubDate>Tue, 30 Jun 2020 07:47:29 +0000</pubDate>
                        <description><![CDATA[I belive my problems lays in Filament Sensor. Sometimes when the filament(PVA) is inside the extruder it just shows 0, after i reset the printer.When i tried to test the sensor with allen ke...]]></description>
                        <content:encoded><![CDATA[<p>I belive my problems lays in Filament Sensor. Sometimes when the filament(PVA) is inside the extruder it just shows 0, after i reset the printer.</p><p>When i tried to test the sensor with allen key or with some ends of  other filament (also tried it with PVA) it always works perfectlly. it always turn to 1. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Elvir</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225856</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225848</link>
                        <pubDate>Tue, 30 Jun 2020 06:57:54 +0000</pubDate>
                        <description><![CDATA[Yes i did, its dry.but most interesting thing is, when i use the function filament unload it retracts normaly. But when I start to print a model it just stays blocked in extruder after the f...]]></description>
                        <content:encoded><![CDATA[<p>Yes i did, its dry.</p><p>but most interesting thing is, when i use the function filament unload it retracts normaly. But when I start to print a model it just stays blocked in extruder after the first layer.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225848</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225847</link>
                        <pubDate>Tue, 30 Jun 2020 06:55:15 +0000</pubDate>
                        <description><![CDATA[Did you dry the PVA before/during use? Moist PVA will easily get grinded by the gears what will result in a blockage.]]></description>
                        <content:encoded><![CDATA[<p>Did you dry the PVA before/during use? Moist PVA will easily get grinded by the gears what will result in a blockage.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Lichtjaeger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225847</guid>
                        <title>Problems with PVA PrimaSelcet retraction</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225844</link>
                        <pubDate>Tue, 30 Jun 2020 06:36:59 +0000</pubDate>
                        <description><![CDATA[Hello guysi need some help. i have problems with PVA filament. the thing just doesn´t want to retract. after printing the first layer it always stays in extruted until MMU error comes out. a...]]></description>
                        <content:encoded><![CDATA[<p>Hello guys</p><p>i need some help. i have problems with PVA filament. the thing just doesn´t want to retract. after printing the first layer it always stays in extruted until MMU error comes out. </p><p>anyone with simiral problem?</p><p>Thanks in advance for any help</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-multi-material-how-do-i-print-this-printing-help/problems-with-pva-primaselcet-retraction/#post-225844</guid>
