Merge two .stl files in to one
I am trying to merge two .stl files in to one with each file having their own colour.
The problem is that after slicing the file seem to have a very slight difference in height the Z axis is jumping up and down and it sounds like the nozzle is catching the other colour.
Do I have to convert each file into a different format fist it did print but looks crap?
I have not had the MMU long so learning curve for me.
Thanks for any help in advance.
RE: Merge two .stl files in to one
Hi David, is the top of your red legs and green area a bit rough?
there looks to be a bit of over extrusion, on those layers...
can you save the project as a .3mf file in Prusa Slicer, then compress the file into a zip file and attach the zip file to your next post please?
He is a diffrent file trying to same thing as would not let me open other one.
I am trying again to see what happen this time.
I have noticed the first layer green went down fine and changed to red no problem but the red first layer is going over the green first layer so after a few more it will higher where it passes over each layer.
Thanks for help.
I got it sorted
I thought prusa sclicer would do it with fist layer but not I redid it in tinkercad and seem to work OK.
Thanks for Help.
PS
I put this in wrong place I have MMU2S
