Filament got clogged?
Pavel Savin
(@pavel-savin)
Hello,
I am dealing with an unplesant problem – I was printing a crown, I tried it for 2 times and both attempts failed near same place. After approx. 6 hours (total time was 8h 30min) filament got stuck – the printer was extruding nothing. I pulled the filament out and there was a bump in the end. In both cases the same bumps. Between the printouts I was printing something else and it was without any problem.
Thank you for your guidence.
Note: Photos were taken from 2nd print.
Posted : 22/12/2021 10:19 am
RE: Filament got clogged?
I would say it is a partial clog.  Have you tried a different filament?
Posted : 26/12/2021 1:41 am
Pavel Savin
(@pavel-savin)
Thank you, I will try different filament.
Posted : 26/12/2021 10:19 am
