Original Prusa Drivers & Apps - 2.2.0
Jakub Dolezal
(@jakub-dolezal)
Member Admin
New version 2.2.1 is out! https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f47/original-prusa-drivers-apps-2-2-1-t25531.html
Hi guys,
here you can find the newest release of drivers and software for MK3/MK2.5/MK2S/MK2, MMU 2.0 and MMU 1.0 . Included is the latest stable release of Slic3r Prusa Edition with integrated firmware updater and many more!
What is new in the version 2.2.0:
New sample objects for the MMU 2.0
- Benchy and Handles
- Gear and Pliers
- Jo Prusa
- Lizard
- Sheep
- more here: https://www.prusa3d.com/printable-3d-models/
New Slic3r PE v1.41.0
- Multi Material 2.0 upgrade support
- Wipe into infill and/or into object
- Reworked object arrangement (place on bed)
- Accurate print time estimates for the stealth mode
- "Remaining time to finish" feature implemented (firmware 3.3.0 or higher required)
- Rotation & scaling of the object
- Upgraded "out of build volume" detection
- Improved wipe tower
- more here https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/slic3r-prusa-edition-1-41-0-final-release--t23511.html
Brand new installer for macOS
- completely new installer
- drag&drop to install functionality
- please remove old drivers before installing this version to avoid duplicity
Supported printers:
Original Prusa i3 MK3
Original Prusa i3 MK3 Multi Material 2.0 (new)
Original Prusa i3 MK2.5
Original Prusa i3 MK2/S
Original Prusa i3 MK2/S Multi Material 1.0
Supported platforms:
Microsoft Windows
macOS
Linux (see Appimage on Github)
Download link:
http://www.prusa3d.com/drivers
Looking forward to your feedback! Happy printing 😉
Previous versions:
New version of Treefrog sample G-code
New Slic3r PE v1.40.1
- Extension of the firmware updater for the MK3 (allowing flash firmware 3.3.0 and higher with the support of localization to CZ, IT, DE, PL, and ES)
- Showing the print bed image for the MK2 and MK3
- Support for the NetFabb STL fixing service under Windows 10
- Improved Octoprint integration
- Improved loading of the AMF files
- Bug fixes (see full Github release )
Supported printers:
Original Prusa i3 MK2/S/MK2.5
Microsoft Windows
macOS
Download link:
New Slic3r PE v1.40.0 (major release)
- Improved G-code preview
- Automatic download of presets
- Printer-specific icons removed. New settings management for all printers and a new configuration wizard
- Enhanced Multi Material support
- Full localization into 7 languages (Czech, French, German, Italian, Polish, Spanish and Ukrainian)
- Detection whether a model fits inside the print volume
- Gyroid infill
- 3MF format support, AMF compression
- And many more (see the Slic3r PE 1.40.0 thread)
Firmware Updater integrated into Slic3r PE
- Update guide refreshed https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.4/66
ColorPrint app removed
- Replaced with online/web version https://www.prusaprinters.org/color-print/
Assembly manuals
/ Knowledge Base
Posted : 09/07/2018 11:10 am
siva.c
(@siva-c)
Re: Original Prusa Drivers & Apps - 2.1.8
I am trying to upgrade firmware for Prusa MK2/S Multi Material. The Windows file appears to have been corrupted. The setup is failing saying that the file is corrupted. Can you upload the correct file?
Posted : 05/08/2018 6:09 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
thanks for the feedback. We will test it and let you know 😉
Assembly manuals
/ Knowledge Base
Posted : 06/08/2018 12:29 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
tested on three MMU1 printers and it works. File is therefore ok. Try reinstalling the driver's package and downloading the .hex file again.
Assembly manuals
/ Knowledge Base
Posted : 07/08/2018 2:43 pm
