how to remove small white tubing - clog (RESOLVED)
prusayo
(@prusayo)
I have MK2s/mmu and I think the white tube has become deformed. I can load filament fine, and push piano wire up into nozzle and there is no problem but filament doesn't extrude. However, although I have the extruder removed (although still connected) I can't remove the white tubing. I use pliers to pull and push the black ring in but won't release. What can I do to release the small white tube? Should the extruder be heated while attempting to remove?
**Update**
I heated the extruder a little and was able to remove and replace it. There was an additional clog that cleared up when I pushed some filament through manually.
Posted : 15/06/2018 11:22 pm
