Filament load time issue
Hi, I need to change filament load time duo to change in length of PFTE tubes, I have put my prusa inside a box and moved the Steppermotors out, and hereby changed the length of tubes, please help me!
Posted : 03/03/2018 4:56 pm
Re: Filament load time issue
I'm asking the same question! I redesigned the extruder mounts so my filament can be fed almost vertically. That made the PTFE tubing too long. I'm assuming they have it pre-programmed to a specific length. Checking to see if it can be changed at all.
Posted : 07/03/2018 2:57 am
Bowden lenghts can be adjusted after doing a factory reset.
https://help.prusa3d.com/l/en/article/SYvbQ66IXF-factory-reset
Posted : 07/03/2018 8:05 am
