Splitting delamination
Best Answer by --:
Dirty bed ... you need the Soap and Water wash; and do it AFTER any other cleaning.
Alcohol rinse: every few prints
- Gloves recommended.
- Once in a while, an alcohol rinse is helpful to remove PLA residue. It does not remove finger oils well.
- Pour a 5 cm puddle of 91%+ alcohol in the middle of the bed, with clean hands use a fresh paper towel to scrub the bed. Wipe up all the alcohol.
Acetone wash: infrequent
- Pour a 2 cm puddle of acetone on the bed, scrub it around with a fresh paper towel. It will evaporate fast as you clean. This step removes PEI oxides that form over time and with heat, and improves PLA adhesion to a like new state.
Hot Water wash: often, as needed, and after any of the above
- Handle the bed only by the edges.
- Wash the bed in hot water, use a fresh paper towel as a wash cloth, with a few drops of plain dish soap (Dawn, unscented, no anti-bacterial, etc.).
- Rinse well in hot water - if you have very soft water, rinse a bit longer.
- Dry the bed with a fresh paper towel.
- Place bed on printer.
Streak test: when contamination is suspected
- With a fresh piece of paper towel, and very clean fingers, dampen the towel with 91%+ alcohol, and wipe the bed side to side moving back to front, like you're painting it with alcohol. The alcohol should be thin enough on the towel it quickly evaporates. If you see any streaks, the bed is dirty and needs a wash.
Napsal : 12/06/2019 11:12 pm
RE: Splitting delamination
Napsal : 13/06/2019 1:15 am
Topic starter
answered:
sorry for the late reply but yes that was a big part of it
i also had to calberate my 3dprinter
i found at -.390 z level works best for me
Napsal : 26/06/2019 5:10 pm
