Strona 2 / 2
Wstecz
Re: Suddenly horrible printing
I actually tried to print it two-color using the gcode change generator on the PRUSA website but I must have missed something; it never asked for a filament change. One of my students did accomplish this (witness the name plates we've been printing all along, which are two-color). I'll have to ask him!
As an aside, you don't have to use the website for this if you don't want to. If you slice using prusa control, after you load your model and select "generate", there should be a window on the right with a slider for adding stops for color changes. Simply move the slider to the correct layer and select before saving the gcode. Why this feature is not readily found in Slic3r PE, I don't know.
Opublikowany : 07/06/2018 1:48 am
Strona 2 / 2
Wstecz
