Internal supports or selective infill without complete infill?
carl-carl
(@carl-carl)
My Project works just fine with 0% infill however in the screenshot it shows the inside of the 0% fill object and you can see the two compartments which clearly needs some kind of support. I understand you can use supports however this only seems to work on the exterior of the object I even attempted to add part, add enforcers, add blockers with no luck.
I wonder if you can select particular parts to infill but not others?
I would really appreciate any suggestion which does not include infill.
Thank you for your time!
Carl
Questa discussione è stata modificata 6 years fa 2 tempo da carl-carl
Postato : 08/06/2019 9:58 pm
RE: Internal supports or selective infill without complete infill?
Repost the image with Link To Media File set ... otherwise all we get is that postage stamp.
Postato : 09/06/2019 1:31 am
Beyond not being able to see what you are doing, Plicer can't add supports inside a part.  That's what infill is for.
Oh, if you don't want infill to support an internal floating in the air portion of the part, print it separately.
Questo post è stato modificato 6 years fa da --
Postato : 09/06/2019 1:34 am
carl-carl
(@carl-carl)
Thank you for the feedback, it seems that you are right going ahead and printing in multiple parts is the only real options, I guess I can glue them tougher once that are printed.
Thank you
Carl
Postato : 09/06/2019 7:30 pm
If they are in contact internally - you are essentially asking for some weird (not in a bad way) bridging constraints.   Slicers will treat the multiple shells oddly, and uniquely based on what I consider random factors.  It's really impossible to predict how a shell will be handled.
I enjoy playing with oddball designs. If you can, zip then upload the stl and I'll have a look.  I might see something the image doesn't reveal.
Your image properly linked ... click to zoom.
Postato : 09/06/2019 7:34 pm
carl-carl
(@carl-carl)
Posted by: Tim
Hi Tim,
Actually that is a accurate description, what I am trying to do is wired haha
Oddball designs are the only ones that make sense when tinkering!
I appreciate the offer however I didn't have much luck with the ZIP but no worries I plan on taking your module based construction advice.
Thanks again
Carl
Postato : 10/06/2019 8:47 pm
